Not exactly woodworking - cutting granite
Forum topic by live4ever posted 07-20-2010 07:53 AM 9224 views 1 time favorited 13 replies Add to Favorites Watch
View live4ever's profile
live4ever
983 posts in 3212 days
07-20-2010 07:53 AM
Topic tags/keywords: question granite counter
Ok, this isn’t exactly woodworking but I figured many here would have experience with this.
I need to cut a modest-sized piece of granite (40”x24”) to width to serve as a countertop on a hutch I am building to match our kitchen. From my research, I see there are two common ways folks do this:
1) Skilsaw + diamond masonry blade, with an assistant keeping a steady mist of water on the blade and cutline. Shallow 1/8” passes.
2) Angle grinder + masonry blade. Dry cut. Assistant with shopvac to catch dust.
Both ways seem reasonable, and personally I’m leaning towards the angle grinder as it’s how I’ve seen installers cut granite, it seems easier to control, and I’ve been meaning to get an angle grinder anyways. :)
Any opinions, tips, advice?
13 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3270 days
#1 posted 07-20-2010 10:11 PM
If this were my project, I would try to get a countertop company to make a template and cut the granite. They have the tools, equipment, and experience to do this quickly – and not wreck your granite.
View wseand's profile
wseand
2796 posts in 3243 days
#2 posted 07-20-2010 10:32 PM
If you are not worried about what the ends look like than I would go with the angle grinder.
View Gene Howe's profile
Gene Howe
11065 posts in 3630 days
#3 posted 07-20-2010 10:58 PM
Rent an over arm (like a radial arm saw) tile saw with a blade bath. That’s what I used in cutting the granite for our kitchen counters, back splash, island and window ledges.
Or, as Sawkerf said, farm it out. For one or two cuts, that’s probably the least expensive and best option.
OTOH, buy the angle grinder, convince the wife you might screw up the cut, take it to a pro and keep the grinder. :-)
View rhett's profile
rhett
742 posts in 3869 days
#4 posted 07-21-2010 12:34 AM
Just keep in mind that the cut will not be “finished” like the top. It will need to be polished to match the glass smooth finish of the top. Having it cut and finished will be half the cost of an angle grinder, a tool with very little woodworking applications.
-- Doubt kills more dreams than failure.
View Dan Lyke's profile
Dan Lyke
1520 posts in 4327 days
#5 posted 07-21-2010 12:46 AM
I’ve done the angle grinder thing on a concrete backed tile countertop and it worked okay, and I’ve used to to straighten up a rough edge on a chunk of limestone so I could match it with a frame better. As others have pointed out, you’re not going to get any straighter line than, say, the thickness of a sharpie, and it won’t be polished, but it works.
I think if I were starting from scratch and looking to do it on the cheap I’d try the circular saw with the spray bottle, because you can water cool it easier than the angle grinder, and it’s easier to set up a board to run the saw along the edge of.
However, what got me posting here was rhett’s assertion that an angle grinder is ”...a tool with very little woodworking applications.” I’m just starting to discover the joy of the angle grinder for woodworking. I’ve seen at least one article about building a jig to control one while it’s got one of those chainsaw-tooth like disks on it for cutting the curve on wood chair seats, but recently I’ve been using it with a sanding disk to carve interesting shapes and curves (at least I think they’re interesting…), which I was inspired to try by episode #10 of Andy's art box tutorial.
live4ever
#6 posted 07-21-2010 01:35 AM
Thanks for the feedback everyone.
It’s a simple cut-to-width and depth operation that would require two cuts, both of which will end up against the wall. So no finishing/polishing required.
I did look into farming it out a while back, and everyone I talked to (3 Bay Area stone fabricators) wasn’t interested and just told me to do it myself. They all felt like it wasn’t worth their time and they’d probably break it.
I have plenty of uses for an angle grinder in woodworking and around the house. So I’m not worried about the cost of the tool. I might just go the circ saw route instead of the grinder. I’ll report back how it goes.
Dan Lyke
#7 posted 07-21-2010 01:41 AM
If you’re North Bay, gimme a holler and maybe we can just meet up. I’ve got the angle grinder and the blade already. I’m in Petaluma.
View Jack Barnhill's profile
Jack Barnhill
366 posts in 3568 days
#8 posted 07-21-2010 01:50 AM
live4ever – I have a similar project going on right now except my my granite’s final size will be 71” X 23”. I got a free piece of 3mm granite from my son’s FIL already bull-nosed on one edge but I have to cut it down to size and cut 2 sink openings. I am planning on using the circ saw for the edge cuts and the angle grinder for the sink openings. I’m about a week or 2 from that part of the project though so I’ll be very interested in your results.
My son’s FIL is a GC specializing in kitchen and bath remodels. He went the circ saw route to cut the piece down to just a few inches longer than I needed.
-- Best regards, Jack -- I may not be good, but I'm slow -- www.BarnhillWoodworks.com
live4ever
#9 posted 07-21-2010 09:32 PM
Dan, thanks for the offer! Unfortunately I’m in SF so it would be a bit of a trek. But my folks are in Novato and I head there often. I’m sure I can find an excuse to meet up…
Jack – I’ll keep you posted. I’ll probably be tackling this with the circ saw this weekend.
Jack Barnhill
#10 posted 07-21-2010 09:54 PM
Thanks & good luck
Dan Lyke
#11 posted 07-21-2010 10:15 PM
shopguryl, you’ve gotta be a bit careful, and it would be a good idea to test your GFI breaker before doing it. The goal is to cool the blade and, secondarily, lubricate the sides of the blade a bit. So if you can keep the water to the blade and the guard you should be fine.
Which is why testing the GFI is also a good idea.
Jack Barnhill
#12 posted 08-17-2010 01:13 AM
I finished my granite cutting yesterday. I used both a Skilsaw and an angle grinder. I used the Skilsaw for the end and back cuts where I wanted them fairly straight and also for cutting a large hole to start the sink openings. I used the angle grinder for cutting the sink openings to final shape.
The 4-1/2” angle grinder didn’t have enough exposed blade to cut completed through the 1-1/8” slab so it was used to make relief cuts from the inside of the sink openings made by the Skilsaw and working my way outward to the final sink shape.
All of the cuts were done dry using diamond blades intended for masonry, tile and stone. The edge of the blades are thicker than the body and have groves to clear material cool the blade.’
As a side note: the angle grinder I started with was an old cheap import rated at 5.8 amps. It sucked. It was slow and bogged down trying to remove the material. I have always hated that angle grinder, ever since I bought it at a swap meet. When I unplugged it to switch saw the ground pin came out of the plugged and didn’t look like it had ever been attached to anything. So I tossed it and bought a DeWalt D28402 from Home Depot. Rated at 10.0 amps and 10,000 RPM it ate up the granite like it was nothing. The second sink opening went much faster than the first.
One recommendation is to put something between the base of the Skilsaw and the granite. The granite dust caught between the Skilsaw base and the granite will scratch the granite. Not a lot but, enough to see it when you look across the surface.
If anyone was to see picture I will try to add them later. Right now I’m at an airport getting ready to board.
I hope this helps. Good luck.
Dan Lyke
#13 posted 08-17-2010 01:19 AM
Thanks for the update, Jack! Good information to file away for when I have to do it.
