Psi tablesaw dust collector, blade guard
Forum topic by alittleoff posted 11-14-2016 03:10 PM 662 views 0 times favorited 7 replies Add to Favorites Watch
View alittleoff's profile
alittleoff
534 posts in 1184 days
11-14-2016 03:10 PM
Are these any good? I can pick one up for about 100.00. Never seen any psi equiptment. Thanks in advance.
Gerald
7 replies so far
4883 posts in 2401 days
#1 posted 11-14-2016 05:20 PM
Personally I would pass. It’s more related to the size of the pipe for the overblade pickup than anything. Choking a DC down to 2” is going to seriously restrict the amount of air it can pull through the tube…hence the amount of dust collected will be restricted. It might work better with a shop vac hooked to it.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2018 days
#2 posted 11-14-2016 06:07 PM
I agree with Fred about the 2” pipe…
They’re expensive, but my Excalibur overarm guard has stayed with me for 16 years and three saws, now residing on a Sawstop ICS. It’s super easy to lock the height to clear a sled or other tool, let it float on sheet goods, swing the entire arm in and out of position, or completely remove it from the saw if it’s in the way. All on-off operations are tool-free and take less than 10 seconds. That means the guard is on the saw, doing it’s job, as often as possible.
View BorkBob's profile
BorkBob
127 posts in 2600 days
#3 posted 11-14-2016 06:19 PM
I have a PSI dust collector and it has worked fine for ~10 yrs. When I was developing a dust collecting blade guard for the BORK, I wanted to stay at 2.5” for the hose. I agree that hooking up to a 4” d/c line is less than optimal.
I dedicated a shop vac to my blade guard and I am very pleased with the results. The only time I have any “dirt” on the table top is when I’m cutting polycarbonate to make more guards. The plastic “dust” is heavier than the wood kind.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
View xeddog's profile
xeddog
177 posts in 2915 days
#4 posted 11-15-2016 06:09 PM
Asking for genuine curiosity, but if you have a 4” hose on your overarm collector, isn’t that going to compromise the under table dust collection? It seems to me that typical hobbyist/homeowner dust collectors would be severely taxed. Also, do you really generate THAT much dust on the top that requires a 4” port?
Wayne
BorkBob
#5 posted 11-15-2016 07:29 PM
I, for one, was talking about hooking up a 2.5” hose from the guard to a 4” hose to the d/c.
#6 posted 11-15-2016 08:06 PM
I have a 4” to the guard and a 4” to the cabinet, and it works well. But I have a fairly large DC also.
View unbob's profile
unbob
802 posts in 1811 days
#7 posted 11-15-2016 08:07 PM
They re expensive, but my Excalibur overarm guard has stayed with me for 16 years and three saws, now residing on a Sawstop ICS. It s super easy to lock the height to clear a sled or other tool, let it float on sheet goods, swing the entire arm in and out of position, or completely remove it from the saw if it s in the way. All on-off operations are tool-free and take less than 10 seconds. That means the guard is on the saw, doing it s job, as often as possible.
I have an Excalibur also, it came with a Delta 12”-14”. I just started using it and I like it alot. The overhead pipe is 4”, with a 3”pipe that slides inside, so it necks down to 3”. I think the dust control was improved on my saw. I would like an overhead guard on my contractors saw, I am looking at the SawStop model, its under $200.
