Oak chairs- refinishing question
Forum topic by Knothead62 posted 07-20-2010 07:08 PM 2646 views 0 times favorited 7 replies Add to Favorites Watch
View Knothead62's profile
Knothead62
2584 posts in 2958 days
07-20-2010 07:08 PM
Topic tags/keywords: question tip
My wife and I have eight oak chairs that we are going to refinish and possibly stain. She started to sand on last night but found that the open grain has the varnish in deep recesses in the grain. It could only be removed with lots of sanding. She was wondering about what to use for stripping first and then sanding. Any suggestions are appreciated. Thanks.
7 replies so far
View Milo's profile
Milo
869 posts in 3316 days
#1 posted 07-20-2010 08:07 PM
While it is NOT my favorite thing to do, I’d definitly strip the finish off those chairs before I tried sanding it off. It should take of finish and stain. The stain is probably in the finish. Some of the orange stripping products out there are not nearly as bad as some of the old “Stripeez” finish removers. You can get them at the Big Box stores.
When I have more time I’ll try and write a more in depth for you.
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View hObOmOnk's profile
hObOmOnk
1381 posts in 4124 days
#2 posted 07-20-2010 08:50 PM
Here’s a stripping product that I use on old furniture, doors and woodwork.
Soy Gel
-- 温故知新
View Gregn's profile
Gregn
1642 posts in 2980 days
#3 posted 07-20-2010 10:32 PM
I use Zip Strip outdoors along with course steel wool when I do a refinishing project. It has worked well but you need to be careful not to get it on you. I haven’t tried the citrus strippers or the soy gel stripper.
Knothead62
#4 posted 07-21-2010 01:35 AM
Hey everybody, thanks for the info!
Knothead62
#5 posted 07-22-2010 02:25 AM
Went to Lowe’s with SWMBO and looked at various stripping stuff. The lady in the paint dept. showed us a “green” product but said green products aren’t as strong as the regular strippers. We are gong to try paint thinner so see if that will cut it some and then sand. Will let you know how it did. Thanks for the replies!
View BertFlores58's profile
BertFlores58
1698 posts in 2919 days
#6 posted 07-22-2010 02:35 AM
A stronger one that I use is the Epoxy reducer… any brand will do. It is a liquid like paint thinner. Just soak the wood and later wipe off. You have to be quick wiping it while wet because it is highly volatile. Not bad for the wood.
If there are still lots of discolorization.. use bleach… A and B. Up to your application. It will turn white evenly but restoring the grain pattern after a new stain is applied.
Hope this will help. But be careful with chemicals.
-- Bert
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3283 days
#7 posted 07-22-2010 08:11 PM
http://www.wmbarr.com/product.aspx?catid=72&prodid=92
I have used this quite a bit. Years ago I refinished furniture professionaly
I’ve had good luck with this type product. It is messy. With anything use good ventilation
I am not sure if this is the same formula I used, but the company is good.
-- http://shepherdtoolandsupply.com/
