How to kill mold?
Forum topic by Gary Glaze posted 1038 days ago 1105 views 0 times favorited 12 replies Add to Favorites Watch
View Gary Glaze's profile
Gary Glaze
10 posts in 1038 days
1038 days ago
I recently sawed some green blackwalnut on my portable mill. I stickered it with 3/8ths inch stickers and placed in my shop. Last night I decided to move the pile and found mold growing on the lumber…...I mean mold like what you would see on a loaf of bread that has been in the cupboard to long. I know all of my errors, but what I really need to know, is how do I kell the mold. I am not sure if the mold is a health factor, but I sure don’t want it to stain or effect the color of the wood. Thanks for your help.
12 replies so far
View Daren Nelson's profile
Daren Nelson
767 posts in 2076 days
#1 posted 1038 days ago
Thicker stickers (3/4 min.) get a fan on it asap…when the surface moisture is gone/lower the mold will die. I don’t expect it to stain the wood any deeper than you are going to surface plane off anyway.
-- http://nelsonwoodworks.biz/
View jusfine's profile
jusfine
2154 posts in 1097 days
#2 posted 1038 days ago
We have access to a product called KILZ.
Made for the elimination – prevention of mold growing.
It is in a white spray can, you could give the existing mold a coating, it will not really penetrate much, but seal the mold from spreading and would be easily planed off when you go to work with your lumber.
As suggested, a fan will keep the air moving through the stickered areas, and it should not spread.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
Rick Dennington
2889 posts in 1365 days
#3 posted 1038 days ago
Greetings Gary,
Just use bleach and water and a scrub brush…... Mix about a 1/3 to a 1/2 cup of bleach in a gallon of water,
stir up good, and scrub the moldy spots….... should take care of the problem…..
Like the others said, get a fan….....
-- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!!
View childress's profile
childress
835 posts in 1713 days
#4 posted 1038 days ago
I’m with Rick, Bleach diluted with water. Although I would just put it in a spray bottle and spray it on. It should kill it, if not on the first spray, spray again, wait about a day before checking each dose and if not completely gone after the second dose, then a little scrub brush. You just need to be careful with a brush because you don’t want to make the mold airborne, that’s what makes people sick. My $.02
-- Childress Woodworks
Rick Dennington
#5 posted 1038 days ago
Greetings childress,
Very good sugesstion on the spray water bottle… I said a gallon because he didn’t say how much wood
he had mold on…. thanks for covering me on that one…!!!
Also… I’ve done this on plywood that I got from the lumber yard where I buy… you have to check the wood
View pvwoodcrafts's profile
pvwoodcrafts
215 posts in 2092 days
#6 posted 1038 days ago
Probably bleach water solution will take care of it. I would recommend getting some 3/4 or 1” stickers and either stick it outside where it’ll get lots of air or put a fan on it inside with a dehumidifier. Its not getting enough air.
-- mike & judy western md. www. pvwoodcrafts.com pvwccf1@verizon.net
Daren Nelson
#7 posted 1038 days ago
I would not use bleach…even diluted on walnut…
View vicrider's profile
vicrider
168 posts in 1069 days
#8 posted 1038 days ago
Diluted household bleach will kill the mold and shouldn’t have any significant effect on the walnut. You will be surfacing (planing, sanding) the wood when you work it anyway.
-- vicrider
View swirt's profile
swirt
1864 posts in 1143 days
#9 posted 1038 days ago
Vinegar is a pretty good mold killer and is a little less caustic to the user than bleach. I have never used it on Walnut, so I can’t say how it might react.
Daren Nelson
#10 posted 1038 days ago
Vinegar will most likely react badly with the tannic acid in walnut (turn black like it does oak)
87268 posts in 1748 days
#11 posted 1038 days ago
I would be concerned using bleach on wood I would suggest naphtha after some warm soapy water and letting it dry before using the naphtha.
Gary Glaze
#12 posted 1038 days ago
Thank all of you for the nice welcome and the great ideas. When I got home this afternoon, I pulled each piece outside, put on my mask, and started scrubing with a long handeled brush. The mold came off easily, but as you noted, I have restacked with a fan behind the lumber and this weekend I will do it one more time and I will cut some new three quarter inch stickers. I also had some quarter sawn honey locust that I had stickered with some old redwood stickers and some pine stickers. The redwood was putting a yellow stain on the wood while the pine was fine. Both species of stickers are completely dry. I don’t know if anyone else has seen this before. Once again, thank you for the help and the friedly welcome. (I will get my daughter to help build my site)
