How would I glue Rubber to plywood?
Forum topic by ChrisCarr posted 07-20-2010 05:37 AM 6575 views 0 times favorited 4 replies Add to Favorites Watch
View ChrisCarr's profile
ChrisCarr
196 posts in 2948 days
07-20-2010 05:37 AM
I am working on something very urgent and need to glue rubber to the end grain of plywood (the edge, where you see the plys.) What adhesive would I use? Also is there a special technique I should use?
View Ger21's profile
Ger21
1075 posts in 3180 days
#1 posted 07-20-2010 05:39 AM
depends on the type of rubber, but probably contact cement.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
13610 posts in 3390 days
#2 posted 07-20-2010 05:48 AM
go here
http://www.thistothat.com/cgi-bin/glue.cgi?lang=en&this=Fabric&that=Wood
they got everything to everything .
View David Kirtley's profile
David Kirtley
1286 posts in 3047 days
#3 posted 07-20-2010 07:07 AM
Actually, rubber cement works pretty good for that.
There are two ways to use rubber cement. The paint it on and stick it together makes a less permanent bond. To make the permanent bond, use it much like you do contact cement. Rough up the rubber a bit with sandpaper. The wood should be roughened a bit as well. Put it on both surfaces and let it dry. Then press them together and apply pressure. (Same way you put patches on a bike innertube.) Should hold on well.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3530 days
#4 posted 07-20-2010 04:01 PM
I would think contact cement would work fine.
-- Wayne - Plymouth MN
