Painting new cabinets
Forum topic by bdresch posted 11-13-2016 07:43 PM 884 views 2 times favorited 19 replies Add to Favorites Watch
View bdresch's profile
bdresch
143 posts in 1603 days
11-13-2016 07:43 PM
I am currently doing built in cabinets for my laundry room. I am building them from birch ply and poplar with the intent of painting white. I have only ever done cabinets in hardwood and stained, so I need some help choosing a finish. What is the best route to go to get a durable white finish? I have also never used a gun, so if there is a good finish compatible with a hvlp gun, this would be a good excuse for me a to buy one finally.
19 replies so far
View SuperCubber's profile
SuperCubber
1025 posts in 2279 days
#1 posted 11-13-2016 10:07 PM
I just used SW ProClassic Semigloss Water Based Acrylic Alkyd for my kitchen cabinets. I have a budget HVLP (Wagner Control Spray Max) that has worked really well for me doing water based dye and poly. I was hesitant to use it for the cabinets, but I figured I would give it a try. It exceeded my expectations. I won’t call the finish factory quality, but I would be really surprised if anyone noticed on their own that they were sprayed by me.
The idea behind the acrylic alkyd paints is that they have many of the benefits of oil based alkyd paints, like hard finish, no blocking (stickiness on latex paint), yet they don’t yellow over time like the oil based ones.
The cabinets have been hung and cured (30 days to fully cure) for about a month, so I can’t yet speak on longterm durability, but I can confirm the finish is very hard and easy to clean.
I actually hung them right away and just prayed my kids wouldn’t destroy them as they cured. That was about 2 months ago. Got lucky on that one!
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
SuperCubber
#2 posted 11-13-2016 10:07 PM
Here is my project post of it: http://lumberjocks.com/projects/273882
View GR8HUNTER's profile
GR8HUNTER
3815 posts in 707 days
#3 posted 11-13-2016 10:53 PM
stain it every1 will be much happier LOL
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
View oldnovice's profile
oldnovice
6841 posts in 3362 days
#4 posted 11-14-2016 06:09 AM
Not to be contrary, when I build something that I am going to paint, I use MDO plywood as it paints beautifully and it never has any surface imperfections.
Secondly for a humid environment I use RustOleum high gloss enamal.
But that’s just me and my way of doing it.
4981 posts in 2488 days
#5 posted 11-14-2016 12:19 PM
I’ve done one set of cabinets that were painted, and it’s a lot more work than staining and top coating. Any imperfections will telegraph through the paint…including wood grain. Using MDO would not be a bad idea. In my case the door panels were MDO, but the carcase was built with a high quality cabinet grade maple ply. Priming with Zinnser BIN smoothed the surface out. Joe is correct that the acrylic enamels will give you a very nice durable finish, and save you the headache of using oil based enamels. They are well worth considering. In my case I used oil based Olympic, but oil based paints are getting harder and harder to find.
SuperCubber
#6 posted 11-14-2016 02:18 PM
MDO would be a good idea for panels. I used 1/4” MDF. It took the paint very well.
View Cooler's profile
Cooler
299 posts in 838 days
#7 posted 11-14-2016 04:29 PM
The only issue with MDF is that the machined edges will “raise grain” if painted with a water-based paint.
I prime with Bin Zinnsser shellac based primer to eliminate that issue. You can just spot “prime” with either Bin or Sealcoat on just the machined edges. The undisturbed flat surfaces finish beautifully.
I just painted some kitchen cabinets with GF “Milk paint” an immitation milk paint. And then top-coated with clear poly. I think that clear poly is a tougher finish and will stay clean longer. The GF milk paint is remarkable for drying entirely free of brushstrokes. I compared it with S-W’s best flat finish and it definitely laid down a smoother and more blemish free finish. Indeed it looked like it had been sprayed on in a professional cabinet shop, and not brushed on with foam brushes in my basement. It will scuff easily so you do have to top coat, but a really nice finish.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
SuperCubber
#8 posted 11-14-2016 05:14 PM
I just painted some kitchen cabinets with GF “Milk paint” an immitation milk paint. And then top-coated with clear poly. I think that clear poly is a tougher finish and will stay clean longer. The GF milk paint is remarkable for drying entirely free of brushstrokes. I compared it with S-W s best flat finish and it definitely laid down a smoother and more blemish free finish. Indeed it looked like it had been sprayed on in a professional cabinet shop, and not brushed on with foam brushes in my basement. It will scuff easily so you do have to top coat, but a really nice finish.
- Cooler
I bet you spent a lot less than I did on that paint too! I thought about that milk paint, but chickened out. I was worried that the grain would show through too much. Glad to hear it works well. I’ll try it in the future.
Cooler
#9 posted 11-14-2016 05:25 PM
- Cooler
I bet you spent a lot less than I did on that paint too! I thought about that milk paint, but chickened out. I was worried that the grain would show through too much. Glad to hear it works well. I ll try it in the future.
- SuperCubber
Of all the brushed finishes I’ve ever used this left the most perfectly even and smooth result. No brush marks at all. But use a foam brush to “mop” up the accumulation in the corners of the stiles and rails.
I did some black cabinets and I wanted a matte finish, but the clear coats with dulling agents made the black finish look more muddy than matte. Completely unacceptable. So for dark colors the dullest I would use is semi-gloss. For white I think it would work with a flat finish.
I was tempted to just use the black without a top coat but the sample board showed scuffing very easily—not an acceptable result for a kitchen cabinet. The paint is listed as “interior/exterior” finish.
oldnovice
#10 posted 11-14-2016 06:34 PM
I still prefer MDO over MDF because MDO is lighter, stronger, the edges can be filled or covered much easier, and other than a tack rag the surface of MDO needs virtually no additional treatment, just apply paint.
MDO also doesn’t create as much airborne dust as does MDF.
Of course MDO costs more than MDF.
SuperCubber
#11 posted 11-14-2016 06:59 PM
MDO also doesn t create as much airborne dust as does MDF.
- oldnovice
I don’t think there is any question as to which one is better. I think it comes down to cost and whether or not any edges will need to be finished. I would doubt there is a significant weight difference per individual cabinet door.
Cooler
#12 posted 11-14-2016 08:10 PM
- oldnovice
None of the local yards seem to carry MDO, or even the light weight version of MDF. I would prefer either. For interior use, I simply rub on pore filler (meant for wood floors). I apply it lit shoe polish. It sands easily and then I coat only the machined edges with shellac or BIN Zinnser. Then paint. The surface of MDF paints better than almost any other. Just the right amount of absorption for good adhesion and it does not devour much paint.
oldnovice
#13 posted 11-15-2016 05:33 AM
Well, that sort of determines your options!
bdresch
#14 posted 11-24-2016 08:07 PM
How about tinted poly or tinted lacquer? I bought a HVLP sprayer so I’m kinda set on something sprayable. Does anyone have any experience good or bad with either of those?
SuperCubber
#15 posted 11-24-2016 08:46 PM
How about tinted poly or tinted lacquer? I bought a HVLP sprayer so I m kinda set on something sprayable. Does anyone have any experience good or bad with either of those?
- bdresch
You can spray the acrylic alkyd. You just thin it with water. That’s what I did.
