Making Drawers - Drawer Lock Miter Bit
Forum topic by Shay posted 01-09-2008 04:05 PM 6828 views 0 times favorited 12 replies Add to Favorites Watch
View Shay's profile
Shay
59 posts in 3799 days
01-09-2008 04:05 PM
Topic tags/keywords: question jig
I’ve got this bit and until now haven’t had the chance to use it. The one thing I wasn’t sure about was doing the sides. I did some googling and found a website demonstrating the use of the bit, but i”m not to sure about his solution for doing the sides. Clamping a piece of scrap wood on the back just doesn’t seem very secure. Any thoughts?
The website is here:
http://www.binkyswoodworking.com/DrawerLockMiter.html
I had originally thought of making a jig that would hold the board vertical and just slide on the table, foregoing the guide and the miter gauge slot and just using the safety pin.
-BlackNoir
-- Centerville, MN - Hobbyist and DIYer
12 replies so far
View Russel's profile
Russel
2199 posts in 3937 days
#1 posted 01-09-2008 04:21 PM
I have one of dem dere bits and when it’s right, it’s right on. However, getting it right is no small feat in my experience. I’ve used featherboards and jigs and stuff, and it’s always hit or miss. I’ve put mine on the shelf where it sits quite comfortably. For me, it was more trouble getting it set up and then cutting the joint, than it’s worth.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3872 days
#2 posted 01-09-2008 04:23 PM
Russel – I had to laugh at how closely your advice about the bit matched the advice in your signature line!
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View Betsy's profile
Betsy
3391 posts in 3893 days
#3 posted 01-09-2008 04:24 PM
Here is another discussion on the bit.
http://lumberjocks.com/topics/1575
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
View rikkor's profile
rikkor
11295 posts in 3872 days
#4 posted 01-09-2008 04:29 PM
I was just thinking about getting one of these. Any other user reviews?
rikkor
#5 posted 01-09-2008 04:31 PM
Thanks Betsy, I just checked your link.
View printman's profile
printman
72 posts in 4071 days
#6 posted 01-09-2008 04:55 PM
I have the square style of that bit shown at the bottom of your link and it is easy to use once you get use to it. Clamping the board does nothing but keep your sides from tilting which can happen somewhat easy so you should use it. The main thing is to experiment with scrap until you have the settings just right for the thickness of stock you are using and then save that scrap for future setup. Using that piece of scrap will save you much time the next time you use that bit. I also use mine for edge gluing panels. it adds about half again as much glue area and that joint will never come apart. Just be careful and don’t get in a hurry because you are taking a fairly large bite out of the wood.
-- St. Louis - just a cut away from finishing!
View Thos. Angle's profile
Thos. Angle
4444 posts in 3960 days
#7 posted 01-09-2008 07:43 PM
The best on the lock miter bit is on woodshopdemos.com. John Lucas has the best demo on how to set up and use this bit. It works every time. I know.
View SawTooth1953's profile
SawTooth1953
327 posts in 3303 days
#8 posted 12-01-2013 07:11 AM
The setup isn’t really that difficult… I believe the ease of use comes from utilizing jigs to support the workpieces during the monstrous bites taken to shape the joint in one pass.
The legacy site of workshopdemos.com has several great demos where the key info shows the jigs to keep the cuts consistent when using the lock miter bit.
-- Spence in Skokie, IL
View BryanatWoodstock's profile
BryanatWoodstock
101 posts in 2031 days
#9 posted 12-01-2013 11:13 AM
View Howie's profile
Howie
2656 posts in 2921 days
#10 posted 12-01-2013 12:46 PM
I’d like to have one of those jigs but choke on the price. Doesn’t look like much there for 50 bucks. I already have the bit. Takes a little tweaking but once it’s set works good.
-- Life is good.
SawTooth1953
#11 posted 12-01-2013 07:07 PM
While setup jigs might save a few minutes of time, it is the stability of the workpieces while passing across the bit that makes or breaks it. I will make the push block set as shown in workshopdemos and give it another try.
And now that I’m thinking about it, why can’t the shaping with this bit be done in 2-3 lighter passes? For other cuts on the router table that would bite too deeply in one pass, I use 1/8” hardboard as either a series of tabletop shims or as fence shims…eg. 3 shims for first pass, remove a shim for second pass, remove another for third pass, then final pass with workpiece on table and against fence. I think it was Pat Warner that suggests that approach so that bit height and fence position are set once, yet you sneak up on the final cut.
View Skippy906's profile
Skippy906
121 posts in 1984 days
#12 posted 12-01-2013 11:57 PM
I use this bit and have had a lot of success with it.
http://www.woodcraft.com/product/2008277/15328/cmt-85550211-drawer-lock-router-bit-12sh-2od-12cl.aspx
Once you have the proper height it works at the same level for the sides and fronts and backs. I have set up blocks I made to get me close to the final height.
-- Making progress
