Earlex 5500, SW all surface enamel finish
Forum topic by OrlandoMark posted 11-13-2016 03:31 AM 1070 views 1 time favorited 10 replies Add to Favorites Watch
View OrlandoMark's profile
OrlandoMark
4 posts in 615 days
11-13-2016 03:31 AM
Topic tags/keywords: earlex 5500 sw all surface enamel spraying oil enamel sherwin williams hvlp thinning paint
Hello All,
My goal is a smooth, “piano-ish” finish on wood furniture, so i bought an Earlex 5500 with a 1.5 needle. After MANY sessions of experimentation, I can’t get rid of the orange peel.
SW says that I’m not supposed to thin past 5%. I’ve thinned to 10% using mineral spirits and am using Penetrol.
Should I thin this alkyd enamel more??? I’ve read that over-thinning effects color and other paint qualitys. I’ve tried different distances and flow rates, but no good results. I’m stumped and nearly defeated.
Thin more?
Thanks,
Mark
10 replies so far
MrUnix
6829 posts in 2253 days
#1 posted 11-13-2016 05:02 AM
I have shot a lot of that SW oil based enamel on both wood and metal with fantastic results. But I do it using a gravity fed HVLP gun w/1.4 tip. I typically thin to about 70/30 or maybe even 60/40. No measuring, just by eye.
5016 posts in 2548 days
#2 posted 11-13-2016 12:04 PM
I’d thin some more. While it might shift the color slightly, it shouldn’t affect the other qualities. Basically all you are doing is applying fewer solids per coat. Thinning waterbornes too much can be a problem, but generally with oil based paints you don’t have those same problems.
OrlandoMark
4 posts in 615 days
#3 posted 11-13-2016 12:36 PM
Gentlemen, thank you for your replies! I’m going to give it another try today and am hopefully for MrUnix results.
View skatefriday's profile
skatefriday
418 posts in 1537 days
#4 posted 11-13-2016 05:48 PM
I have an Earlex and found that, at least with EnduroVar, applying a thin coat produced more orange peel than a thicker coat.
OrlandoMark
4 posts in 615 days
#5 posted 11-14-2016 12:09 AM
I sprayed again today with paint thinned to 30%. I definitely got better results, but not glass.
If i spray too light a coat, it becomes a very fine, rough texture. If I spray heavier, I got mild orange peel. I am a beginner at spraying, but there certainly does seem to be a learning curve or I maybe I need to thin to 40-50%.
If anyone knows where a picture is of how the paint is supposed to look directly after spraying, that would be helpful. I’ve read that it’s normal for the paint to look like orange peel when wet, but it’s supposed to flatten out after about 15 min. (I wish!)
Maybe a different paint selection would be easier. I’m looking for durability which is why I chose SW oil enamel.
View Carloz's profile
Carloz
1147 posts in 646 days
#6 posted 11-14-2016 11:53 AM
Add some penetrol.
OrlandoMark
4 posts in 615 days
#7 posted 11-16-2016 12:31 PM
I took a couple pics of the 2 types of results that I get. One appears to have too heavy a coat, has a nice shine, but up close it’s obviously not flat.
he other shows a lighter coat that is “flatter” than the other, but doesn’t have any shine due to the fine textured appearance.
Additional analysis, advice or berating and is appreciated.
View Cooler's profile
Cooler
299 posts in 898 days
#8 posted 11-16-2016 02:37 PM
I toured the Steinway factory shortly after they switched from solvent based lacquer to water bases lacquer. They emphasized that it was a lacquer. It looked “piano-ish” to me.
I will say that when I bought my Scion it was the first year Toyota was using a water-based paint, and that paint was very soft when I got it. You could scratch it with your thumbnail. And brushing against my shrubs while going onto my driveway left marks on the finish that I had to rub out.
But it hardened after about a year. The newer finishes are much better. I think because they are using a clear-coat.
There is a finish called “Pianolac”. I have no experience using it. https://www.mmdigest.com/Archives/Digests/200202/2002.02.09.07.html
Also GF makes a water based lacquer with a Gloss of 90: https://generalfinishes.com/professional-products/water-based-topcoats-and-sanding-sealers/enduro-water-based-lacquer#.WCxtstIrLIU
Mohawk also makes a piano-specific finish and it can be sprayed with HVLP equipment. It is just $46.00 per gallon and that sounds pretty reasonable for a specialized product like this: http://www.richelieu.com/documents/docsPr/M6/10/13/07/M6101307/1385402.pdf
http://www.mohawkproducts.com/product-p/pl.htm
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
View Drew's profile
Drew
350 posts in 3155 days
#9 posted 11-16-2016 06:58 PM
A “piano-ish” finish is achieved by using a thing called “elbow grease”. Sand your finish flat, then shoot with clear. Let that dry for 4+ days, then back to elbow grease.
-- TruCraftFurniture.com
Cooler
#10 posted 11-16-2016 07:38 PM
- Drew
Not at the Steinway factory. The finish was sprayed on and was 99% there when it came out of the booth.
But you can certainly get a mirror finish using shellac and French polish. A huge amount of work, and probably not cost-effective for Steinway.
