Ixion Crank Drill
« back to Hand Tools forum
Forum topic by Ocelot posted 11-12-2016 10:58 PM 1024 views 0 times favorited 3 replies Add to Favorites Watch
View Ocelot's profile
Ocelot
2071 posts in 2783 days
11-12-2016 10:58 PM
Have any of you folks ever used an Ixion crank drill?
I saw two of them on ebay recently for reasonable prices, and picked one up.
It has an enclosed gear box with a crank which can be attached to one of two drive points. One (high speed) turns the chuck about 7 1/6 times per crank, and the other (slow speed) turns the chuck about 2 1/2 times per crank.
The thing is quite heavy cast iron with steel covers on the gear box. I’ve not opened it for greasing.
In a first attempt, it seemed hard to use – hard to turn past the top and bottom points.
In general, what is the typical drive ratio for hand-crank drills? Is there a tutorial around here for how to use them?
Thanks,
Here’s a photo of the one I didn’t buy that’s still on ebay.
3 replies so far
View Don W's profile
Don W
18962 posts in 2712 days
#1 posted 11-13-2016 09:34 PM
I’ve got a Xion Egg Beater
Marked XION, Germany.
That the only help i can give,
Ocelot
#2 posted 11-15-2016 10:29 PM
Thanks Don,
Sorry to take so long to reply. Ixion is also German. Are you sure yours is not Ixion? I’ve seen some open-gear Ixions on ebay.
Also, I’ve seen a Stanley that looks like mine – only the gear covers are a little different.
I’m guessing I just need to clean the gear train and go from there.
Don W
#3 posted 11-16-2016 05:08 PM
It could be. I’ll take a closer look.
