Lathe tools-HHS & Chrome Vanadium steel?
Forum topic by eastside posted 07-19-2010 04:19 PM 4950 views 0 times favorited 1 reply Add to Favorites Watch
View eastside's profile
eastside
97 posts in 3131 days
07-19-2010 04:19 PM
I picked up a set of Freud lathe tools from Craigs list and the steel is not HHS. It is stamped with Chrome Vanadium and with a little research i found out it is RC 50-60. So is that another way of saying High Speed Steel? I think the steel might be the same as bench chisels which means that i have to be carefull not to over heat the tip when grinding. Does anybody know the difference of the two steels? Oh ya the Freud model number is TT-108 they sold for around $100.00 when new. They are no longer made.
-- Mike, Westport MA.
1 reply so far
View richgreer's profile
richgreer
4541 posts in 2944 days
#1 posted 07-19-2010 04:41 PM
I’m not an expert on this but I think you should assume that you can overheat these tools. The good news is that you should be able to get a sharper edge on them. The bad news is that you will have to sharpen more often and be careful not to overheat them. Dip them in a water bath frequently when sharpening.
