Protective Finish Over CN Blotch Conditioner and Gel Stain
Forum topic by BigMig posted 11-11-2016 08:14 PM 1265 views 0 times favorited 5 replies Add to Favorites Watch
View BigMig's profile
BigMig
440 posts in 2637 days
11-11-2016 08:14 PM
Topic tags/keywords: finish cherry blotch plastic
I’m almost done with the project – but I want to apply a top coat/finish on a small indoor bench made from cherry. I first treated it with Charles Neil’s blotch preventer, then applied a gel stain (Bartley’s). Now it’s time for a protective finish.
What suggestions do you have for me? – I don’t own a spray system, so it’ll have to be applied by bristle or foam brush, cloth or perhaps rattle can. Since it’s a small indoor bench, I’ll probably need only moderate protection – unlike a dining table. Lastly, I don’t want a “plastic” look to it because the wood is beautiful. Maybe a satin finish?
What would you use? Don’t worry about being too specific, either.
And – thanks in advance for your thoughts, opinions, etc.!
-- Mike from Lansdowne, PA
5 replies so far
View Carloz's profile
Carloz
1147 posts in 615 days
#1 posted 11-11-2016 09:57 PM
I did the same and used shellac on a sofa table, Then for a coffee table I also used shellac for the bottom and Arm-R-Seal for the top. The latter even though it is a polyurethane does not have any plastic feel and actually brings wood grain even better than shellac. maybe because it is oil based.
View Richforever's profile
Richforever
757 posts in 3744 days
#2 posted 11-12-2016 12:59 AM
I like to use three coats of Varathane brand polyurethane matte finish. It’s water-based and goes on easily. It doesn’t make the object look like plastic; and it’s described as a “soft touch” finish. Two coats can go on in one day and then the last one goes on the next day. I use it over oil-based finishes. It’s sold at my home depot down the street.
-- Rich, Seattle, WA
BigMig
#3 posted 11-12-2016 04:45 AM
Thanks guys! Any other ideas? Is Waterlox a product to use here?
View CharlesNeil's profile (online now)
CharlesNeil
2410 posts in 3894 days
#4 posted 11-12-2016 01:40 PM
1x to Arm R Seal
BigMig
#5 posted 11-14-2016 02:32 PM
Thanks to Charles, Rich and Carloz – I began applied a coat of Arm-R-Seal on Friday. Let it sit overnight, then 0000 steel wool and second coat yesterday. The Arm-R-Seal is so easy to apply with a cloth…I like that. And – it looks great. Third coat goes on today; then I’ll post a couple of photos.
It’s a simple piece, but I got to practice half-blind dovetails and wedged through mortises (both by hand). Definitely not a “pro-job” but I’m happy with it for my level of experience.
Cheers! Thanks again.
