Bench top Mortiser Chisel
Forum topic by flyboy posted 07-19-2010 02:31 AM 1221 views 0 times favorited 8 replies Add to Favorites Watch
View flyboy's profile
flyboy
96 posts in 3183 days
07-19-2010 02:31 AM
Hi, I have what is probably a very stupid question. What woud be the right size chisel to use if the wood I use is primarily 3/4” stock. My sisters surprised me with a new Powermatic PM701 which does not come with chisels. I am looking to buy one new chisel every month but didn’t know if a 1/4”, 5/16”, or a 3/8” would be the first. I appreciate any help. Thanks, Flyboy
-- 160th S.O.A.R
8 replies so far
View barryvabeach's profile
barryvabeach
159 posts in 2952 days
#1 posted 07-19-2010 02:39 AM
I would get a 1/4 chisel – in general a tenon should be 1/3 the thickness of the stock – which leaves 1/4 inch of material on either side of the tenon.
View cutmantom's profile
cutmantom
401 posts in 2943 days
#2 posted 07-19-2010 02:40 AM
1/4 inch, but a set may be a good way to go, don’t settle for cheap ones, they will give you problems like burning
13594 posts in 3249 days
#3 posted 07-19-2010 02:41 AM
for 3/4” stock ,
i use 1/4” chisel .
for 1 1/2 ,
a 1/2” chisel ,
the tenon 1/3rd the stock thickness ,
if you make then 1/2 ratio ,
the mortise cheeks are to thin .
Rick Dennington
5698 posts in 3102 days
#4 posted 07-19-2010 02:55 AM
Greetings flyboy,
Why not buy all 4 at the same time, and have them on hand when you’re ready to use them. It’ll be cheaper in the long run…...
View SnowyRiver's profile
SnowyRiver
51457 posts in 3388 days
#5 posted 07-19-2010 03:20 AM
I agree with everyone. I think it would be easier though just to buy the set. It probably would be cheaper too.
-- Wayne - Plymouth MN
View BillyJ's profile
BillyJ
622 posts in 3111 days
#6 posted 07-19-2010 05:02 AM
WOW – I wish I had siblings that liked be that much! Congratulations. I’m sure you could find a set for under $50 – that way you would be set.
-- I've never seen a tree that I wouldn't like to repurpose into a project. I love the smell of wood in the morning - it smells like victory.
flyboy
#7 posted 07-19-2010 06:00 PM
I wanted to say thanks for everyone’s help. This is why I truly love this site and the people on it. I am a lucky man to have sisters like I do. With 13 siblings I have not one complaint. I wanted to buy one at a time so I can buy the very best that I can. I feel that it’s better to buy that best you can afford once rather than crap several times. I have read good reveiws on the Powermatic chisels so I am off today to get my 1/4” chisel. Thanks again to all. Flyboy
-- 160th S.O.A.R
View Rob Bois's profile
Rob Bois
33 posts in 3302 days
#8 posted 07-19-2010 07:23 PM
The rule of a tenon being 1/3 the width of the stock is fairly traditional, but I would suggest a wider tenon is likely a bit stronger. I use 3/8” mortises and tenons for all my 3/4” stock as this gives me tenons half the thickness of the material. Plus, a 3/8” mortising machine chisel is less likely to get clogged with chips since you have a bit more clearance for chip ejection.
