Table saw flatness
Forum topic by BlacksheepWW posted 07-18-2010 03:31 AM 1067 views 0 times favorited 4 replies Add to Favorites Watch
View BlacksheepWW's profile
BlacksheepWW
9 posts in 3078 days
07-18-2010 03:31 AM
I have an older Delta contractor saw, I was trying to adjust the blade to 90deg. and to the left of the blade I’d get it set to 90deg. and right of the blade would be out. so I put a straight edge across the width of the cast iron top over the throat plate area and from left to right of the top, its not flat by .016” out.
I was wondering what is the normal flatness and how to correct this problem or adjust for it.
View araldite's profile
araldite
188 posts in 3518 days
#1 posted 07-18-2010 03:51 AM
Check without the throat plate. Make sure you’re testing to the plate of the blade and not to the tooth.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
TopamaxSurvivor
18355 posts in 3790 days
#2 posted 07-18-2010 08:03 AM
Hmmmm! Learned something on here again today :-) I never would have thought of that.
BlacksheepWW
#3 posted 07-18-2010 07:23 PM
I did check it with the throat plate off and with the blade body and not on the teeth.
At first I thought the problem was the plate, but it’s not.
View knotscott's profile
knotscott
8120 posts in 3490 days
#4 posted 07-18-2010 10:26 PM
The best method for checking flatness is to check the accuracy of the cut. It takes a pretty hefty deviation from flat to effect the cut, depending on where it is.
Tom Hintz's TS alignment technique
