Non-yellowing finish for white pine ceiling?
Forum topic by bringitonhome posted 07-18-2010 02:22 AM 26927 views 0 times favorited 9 replies Add to Favorites Watch
View bringitonhome's profile
bringitonhome
28 posts in 3037 days
07-18-2010 02:22 AM
Hi folks-
can someone recommend a topcoat that I can use for a white pine ceiling that won’t yellow? I understand pine yellow with age, but I’d like to preserve the natural color for as long as possible.
I tested some general finishes arm-r-seal polyurethane – yellow right out of the can. Popped the grain beautifully though…
any advice greatly appreciated.
9 replies so far
View canadianchips's profile
canadianchips
2600 posts in 2959 days
#1 posted 07-18-2010 02:51 AM
Satin finish :Minwax – poly acrylic works quite nice. Can be costly.
Some people use a solution of white paint thinned out real thin, wipe it off quiclky. I think the process is called “Pickling” Try it on scraps first,
View wisno's profile
wisno
88 posts in 2973 days
#2 posted 07-18-2010 09:24 AM
Pine wood has yellow color base. That is the color. I don’t think the yellowing in your finish will affect the color of your finish.
But anyway You can do with a non yellowing lacquer (cellulose acetate butyrate clear coating or acrylic clear coating) to prevent yellowing in your finish.
You also can use a non yellowing polyurethane clear coat.
Good luck
wisn
-- http://www.wisnofurniturefinishing.com/
View Greedo's profile
Greedo
473 posts in 2922 days
#3 posted 07-18-2010 09:36 AM
yup, the thing i found that alters or yellows the least the natural color of the wood is clear acrylic varnish. makes the wood look like it is when it is wet.
i love pine and the way it looks when un treated, but once you treat it it changes completely from almost white to deep yellow. thats why i generally use a finish with a light oak stain, makes it look alot richer and not as agressive as the usual yellow color you get with regular varnisches.
View docholladay's profile
docholladay
1287 posts in 3021 days
#4 posted 07-18-2010 10:38 AM
Minwax, water based polyurethane works best for me. The oil based version will yellow the wood some, but the water base seems to be more clear.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View SnowyRiver's profile
SnowyRiver
51457 posts in 3442 days
#5 posted 07-18-2010 02:42 PM
You could use Minwax waterbased Polycrylic. It will give you a clear finish, however, pine natuarally turns a bit yellow over time.
-- Wayne - Plymouth MN
16274 posts in 4180 days
#6 posted 07-18-2010 03:36 PM
What Wayne said.
bringitonhome
#7 posted 07-19-2010 02:55 AM
ok i picked up some polycrylic. threw on two test coats – so far so good. Only a little yellowing.
Regarding the yellowing – I happened to come across some 50+ year old knotty pine scraps from another part of the house we demo’d. It was a dark, dark orange. No idea what it had been treated with. Will all pine eventually turn that dark? Even if it is sealed?
View CampD's profile
CampD
1648 posts in 3448 days
#8 posted 07-19-2010 03:08 AM
I 4th polycrylic!
-- Doug...
SnowyRiver
#9 posted 07-19-2010 03:12 AM
Yes, pine will usually turn yellow over time no matter what is applied for a sealer. The light will actually darken it.
