OSS: How much vibration is too much? Also is this a good tool to sand MDF profiles?
Forum topic by Propaganda posted 1068 days ago 604 views 0 times favorited 7 replies Add to Favorites Watch
View Propaganda's profile
Propaganda
4 posts in 1069 days
1068 days ago
Topic tags/keywords: sanding mdf oss
Hey hey
Ok, so I am trying to find a solution to sanding the edges of MDF. The thing is the edges are in funky shapes like stars, butterflies, guitars, and such.
I bought a harbor freight spindle sander to try out. Using the 80 grit takes far too much material off and I will be buying a set of 150 grit ASAP to try. (the edges are sealed with Kilz) The vibration on the spindle closest to the table is about .008” and on the top its about .014” (jumps to .020” at times). I am curious to know if higher end spindle sanders have far less runout and also how much runout is too much? As you can tell I basically have no experience at this and I don’t want to be stuck with a $130 tool that does not do a professional job and have to spend $500 on a real OSS.
Are there other solutions to sanding odd shape edges of MDF? Hand sanding for a complicated unit takes 30 minutes! There are a few inside corner radiuses of 1/4” and I think I will take a small dowel cut a slot thus making a super small flapper sander. IDK.
Thanks
-R
-- "Gentlemen, you can't fight in here this is the war room!"
7 replies so far
View Gene Howe's profile
Gene Howe
3217 posts in 1626 days
#1 posted 1068 days ago
The Rigid OSS is only $70 more and you get a oscillating edge/belt sander with it.
For really small cut outs I built a manual strip sander which is the simple shape of a coping saw cut from 1/4” plywood with a ripped piece of cloth back belt glued to it as the “blade”.
If you use a scroll saw, there are sanding strips that replace the blade and can get in tight places.
View iamwelty's profile
iamwelty
218 posts in 1313 days
#2 posted 1068 days ago
+1 X 10 on the Ridgid. The Belt really adds to shape option and you can easily change to the spindles as needed, plus you get life time warrant, a large tilting table, dust collection…
-- There is a fine line between eroticism and nausea...
View richgreer's profile
richgreer
4472 posts in 1272 days
#3 posted 1068 days ago
For small odd shaped items, I use a strip sander with either a 1” or 1/2” sanding belt. IMO that is the best way to sand small odd shaped items.
My particular strip sander is an accessory for my shopsmith. I’ve never seen anything quite like it as a stand alone unit. It is capable of doing internal sanding (like the inside of a circle).
View canadianchips's profile
canadianchips
1781 posts in 1194 days
#4 posted 1068 days ago
I recommend a !” Strip sander.
View lew's profile
lew
9036 posts in 1953 days
#5 posted 1068 days ago
My spindle sander has several different sized spindles. If dirt gets into the “threaded socket”, when changing spindles, it will cause this problem.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
Propaganda
#6 posted 1068 days ago
Thanks guys, but has anyone taken the time to measure vibration and runout with a dial gauge?
View Ger21's profile
Ger21
594 posts in 1328 days
#7 posted 1067 days ago
I don’t have any noticable runout on my Delta BOSS.
-- Gerry, http://home.comcast.net/~cncwoodworker/CNC_Woodworker.html
