Planer stutters after newly sharpened blade
Forum topic by Clobby posted 11-08-2016 03:10 PM 881 views 0 times favorited 21 replies Add to Favorites Watch
View Clobby's profile
Clobby
16 posts in 811 days
11-08-2016 03:10 PM
Topic tags/keywords: planer stutters
I just bought a used planer, that had some knicks in the knives. It worked great other than the knicks, no issues whatsoever. I brought the knives to a tool grinding shop that professionally sharpens all sorts of blades. Got them back, they looked great, not as sharp as my chisels but should do great for the planer I thought.
Long story short, the planer now stutters when planing. It feeds just fine with no blade contact, and I’ve reset the knives height using the included gauge with the planer 3 times. All dust/debris has been cleaned out, no obstructions from what I can see. I’m at a loss.
Could the blades be too dull? No idea what else it could be. I’ve recorded the issue so you can see it yourself, but be aware the audio is loud!
Youtube video
Imgur Link to Pics of result
-- Wood working newbie, IT Pro for 15 years, ask away for computer help to help repay all the noob wood working questions.
21 replies so far
View Redoak49's profile
Redoak49
3740 posts in 2227 days
#1 posted 11-08-2016 03:35 PM
Are the feed rolls slipping. How is the surface finish.
On my planner, DW735, the blades need to be the proper width as there is no adjustment for width like on my 15” planer where you set the paperweight. I think you should measure the blade width as after grinding they may be too narrow.
View Bill White's profile
Bill White
5148 posts in 4198 days
#2 posted 11-08-2016 03:43 PM
+1 on checking the feed rollers. How are they driven? Chain, belt?
Bill
-- bill@magraphics.us
Clobby
#3 posted 11-08-2016 03:57 PM
Could the feed rollers work fine when the knives aren’t cutting but it’s just being fed through like in the first pass , but once the cutter head is doing its job start stuttering?
Not sure on whether it’s chain or belt driven, its the same planer as Matthias Wandel uses, just different branding if anyone has any idea.
Clobby
#4 posted 11-08-2016 03:58 PM
- Redoak49
Width as in is it still exactly 12.5” wide? Or you mean the thickness(I think its about 3/16” thick blade). I’m not sure how/why the 12.5” would have an effect, maybe someone can elaborate?
Also, could I only install one knife to see if I can rule out one side of the cutter head, or is that a bad idea?
View OSU55's profile
OSU55
2028 posts in 2228 days
#5 posted 11-08-2016 05:17 PM
Try cleaning the planer bed with solvent such as mineral spirits and then apply furniture wax (any wax w/o silicone). Sand down any raised metal on the bed – I use 600 grit, then buff with steel wool and wax. I find the bed getting sticky to be much more of an issue than feed rollers, but check them if there is still a problem. I clean the rollers with denatured alcohol.
View Aj2's profile
Aj2
1950 posts in 2036 days
#6 posted 11-08-2016 05:31 PM
Sounds like something is striking the wood in the cutting circle other than the knife edge.
Could be the heal of the bevel?
Are your knives indexed or did you set the knife height?
Aj
-- Aj
View HokieKen's profile
HokieKen
7565 posts in 1377 days
#7 posted 11-08-2016 05:32 PM
This may be a dumb question but, you don’t have the knives in backwards do you?
-- Kenny, SW VA, Go Hokies!!!
Redoak49
#8 posted 11-08-2016 05:35 PM
Blade length is 12.5, blade thickness 3/16” , and blade width is what. The distance from the locating holes to the tip of the blade is important. If you ground too much off during sharpening then it may not cut properly. In addition all blades need to be the same.
It would be helpful to list the brand and model. This is is always true when asking help on a machine problem.
View mrbob's profile
mrbob
182 posts in 807 days
#9 posted 11-08-2016 06:37 PM
This may be a dumb question but, you don t have the knives in backwards do you?
- HokieKen
Not a bad thought.
Clobby
#10 posted 11-08-2016 06:43 PM
- HokieKen
Not a bad thought.
- mrbob
I’m starting to think this honestly, I thought I put them in correctly, but the blades were off for about a week, and I could have put them in backwards. Does the cutterhead spin with or against the direction of the rollers?
View Aj2's profile
Aj2
#11 posted 11-08-2016 07:27 PM
- Clobby
Are you sure you want to pursue woodworking on your own?
Aj
-- Aj
Clobby
#12 posted 11-08-2016 07:30 PM
Aj
- Aj2
Awesome reply mate, very helpful!
View diverlloyd's profile
diverlloyd
3286 posts in 2095 days
#13 posted 11-08-2016 07:58 PM
Have you checked the blade tightness? The blades should be flat side down.
Clobby
#14 posted 11-08-2016 07:59 PM
I’ll check on all these suggestions tonight when I get home from work, I have the same planer as Matthias Wandel so I just followed his guide, so after double-checking his site, im 95% sure blades are on correctly, tightened down as much as he said to do, but I’ll double-check all tonight and reply back with what I find.
HokieKen
#15 posted 11-08-2016 08:20 PM
- Clobby
The cutterhead spins opposite the rollers. The rollers move the board through while the cutterhead turns in the opposite direction to cut against the travel. The flat (unbeveled) face of the knives should be leading in reference to the rotational direction of the cutterhead.
