A zero clearance table saw insert from ALUMINUM
Forum topic by Planeman40 posted 11-07-2016 03:00 PM 1300 views 0 times favorited 8 replies Add to Favorites Watch
View Planeman40's profile
Planeman40
1229 posts in 2875 days
11-07-2016 03:00 PM
Topic tags/keywords: tip zero clearance insert
I have a Hammer sliding table saw that has a long thin opening for the saw blade. I tried making a zero clearance blade insert from wood but found it to be too flimsy. Then I tried making one out of aluminum and it worked like a charm! Many woodworkers forget aluminum can be easily cut with woodworking carbide blades and even regular steel saws. I thought I would post this to let many of you know this can be easily done with a wood cutting bandsaw, a floor mounted belt sander, and a carbide tipped table saw blade. I just raised the saw blade while the insert was in place to cut the slot as usual.
Planeman http://s44.photobucket.com/user/planeman3160/media/Zero%20Clearance%20Insert%20of%20Aluminum%20for%20Hammer%20Table%20Saw-%20by%20R.Carswell%202016_zps6ujo0oop.jpg.html
8 replies so far
View MrRon's profile
MrRon
4986 posts in 3358 days
#1 posted 11-07-2016 05:25 PM
Great idea. I cut aluminum regularly on my table saw and band saw. Cutting on the table saw is a bit of a problem. The sharp aluminum chips fly back and leave small cuts on hands, arms, face and down my shirt. I’ve tried covering the cutting area in an attempt to deflect the chips, but that makes it hard to control cutting progress. I’ve cut material as thick as 3/8”. Cutting on the band saw is not a problem. Maybe a plexiglass shield will work. BTW I use safety glasses.
View splatman's profile
splatman
586 posts in 1513 days
#2 posted 11-08-2016 12:20 AM
YouTuber Marius Hornberger made 0-clearence inserts for his Hammer sliding TS.
If your TS is anything like his, you could still have used wood.
Planeman40
#3 posted 11-08-2016 12:36 AM
A plexiglass shield and safety glasses take all the sport out of it! ; )
By the way, can anyone direct me to instructions of how to go about using Photo Bucket to place photos in these threads?
Planeman
View Williams319's profile
Williams319
4 posts in 679 days
#4 posted 11-08-2016 02:34 AM
Aluminum, good idea as other have said dodge the chips and make sure it is held down well when raising the blade.
View BobAnderton's profile
BobAnderton
283 posts in 2905 days
#5 posted 11-08-2016 03:32 AM
Planeman, you don’t need Photobucket. If you have the picture saved as a file you can use the button labeled “img” just above the box where you type the text. It will have you point to the picture you want to post to the thread when you hit “choose file” and then hit “insert this image”.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
runswithscissors
2818 posts in 2139 days
#6 posted 11-08-2016 05:36 AM
I wear a full face mask when cutting aluminum, plus welding gauntlets. And I learned not to wear fleece, as the chips stick like burrs. You need long nose pliers to pick them out.
Also, aluminum likes to stick to the face of carbide teeth. If it builds up too much, you get slow cutting and a lot of heat buildup. A dose of WD 40 helps control that.
Planeman40
#7 posted 11-08-2016 01:27 PM
Thanks Bob! I should have seen that. “If brains were shoes I would be barefoot all the way to my knees!” ( a comment once by Pogo . . . IF you are old enough to know who Pogo is)
View Kelly's profile
Kelly
2071 posts in 3058 days
#8 posted 11-09-2016 03:52 AM
I cut all my guides for my jigs from 3/8” plate. I went ahead and bought a carbide non-ferrous material blade and use it so I won’t beat my wood blades. Before that, I used a fine tooth carbide blade and got VERY nice results.
Safety glass are not a mere option, as others point out.
