PC557 biscuit joiner kit
Forum topic by fiddlebanshee posted 07-16-2010 02:36 AM 1338 views 0 times favorited 6 replies Add to Favorites Watch
View fiddlebanshee's profile
fiddlebanshee
227 posts in 3095 days
07-16-2010 02:36 AM
I bit the bullet today and got the PC 557 biscuit joiner. I haven’t tried it out yet, but have opened the package and tried turning all the knobs to see what they do, with the manual beside me. The knob that changes the cutting depth for the various sizes biscuit is really hard to turn. What can I do about that? Is it normal or should I return the unit as defective?
Your advice is greatly appreciated.
-- As if I needed another hobby!
View Cato's profile
Cato
701 posts in 3461 days
#1 posted 07-16-2010 12:53 PM
Try the plunging action a few times before you return it. Could be that will loosen up the cutting depth for different biscuit sizes.
View barryvabeach's profile
barryvabeach
159 posts in 3193 days
#2 posted 07-16-2010 01:07 PM
I have had mine for years and that knob is pretty stiff, but I don’t consider it a defect. It is extremely rare to change it – It is nearly always on 20. If I am working on something that will only handle 10 , I switch it to that , then turn it back when I am done. As long as it isn’t stuck solid, I would use it.
View RH913's profile
RH913
52 posts in 3134 days
#3 posted 07-16-2010 01:33 PM
Mine is tight too
Terrific tool
-- RALPH
View Sarit's profile
Sarit
550 posts in 3289 days
#4 posted 07-16-2010 01:47 PM
There’s a nut opposite to the knurled knob thats used to lock the depth adjustment bolt. Once you loosen it, it should be easy to turn. It needs to be re-tightened when you’re done.
I used an adjustable wrench to loosen it the first time.
fiddlebanshee
#5 posted 07-16-2010 04:50 PM
Thanks all for your replies. I’m glad to know it wasn’t me, or the particular item. I think I can live with it and will turn it to 20 and leave it there.
Rick Dennington
6179 posts in 3343 days
#6 posted 07-16-2010 07:00 PM
Greetings fiddle,
I don’t have a Porter-Cable, but I”ve got a DeWalt, and it does the same thing when you switch from #20’s to 10’s to 0’s….. I think they are made like that. I don’t know if there is a spring in there to keep it from “jumpng” out of one into the other or not…. They all do it, so nothing to worry about as far as I can see.
-- " It's a rat race out there, and the rats are winning....!!"
