Max Inlay Thickness
Forum topic by Ivan posted 07-15-2010 08:53 PM 1096 views 1 time favorited 3 replies Add to Favorites Watch
View Ivan 's profile
Ivan
185 posts in 3342 days
07-15-2010 08:53 PM
Topic tags/keywords: question
Hello All,
I am thinking of adding some inlay to my work and was thinking that it might be a good way to ‘cover up’ knots in wood. Thinking that wood likes to move, and an inlay that is the full thickness might have different movement, what would you recommend for the maximum thickness of an inlaid piece?
Would you say that 1/2 the thickness is max or should I think of this as veneer and not exceed 1/8”?
Inlaying in a wood that will move and not veneering over a stable platform (MDF) makes me worry that the inlay will eventually be torn apart by the ‘host’ wood or pushed out due to seasonal movement.
Thoughts??
Ivan
-- "Do it right the first time, you'll just kick yourself later..."
3 replies so far
View DrDirt's profile
DrDirt
4423 posts in 3707 days
#1 posted 07-15-2010 09:12 PM
Depends on the detail of the piece. For example folks will put in butterfly keys for splits and they are usually the full thickness. If one were looking to inlay a detailed piece, like leaves and rose petals, I would stick to depth/thickness of ~1/8 inch, If I were covering a knot, I would fill with Epoxy first then route/chisel for the inlay.
View jusfine's profile
jusfine
2422 posts in 2890 days
#2 posted 07-16-2010 05:54 AM
The inlay I use for the plaques I make or on trophies is about 1/4” and I have had no problems…
-- Randy "You are judged as much by the questions you ask as the answers you give..."
Ivan
#3 posted 07-16-2010 03:38 PM
Thanks, I was concerned about the inlaid pieces being too thin and if the floor needs to be redone then they will be torn out or sanded through.
