Need help fixing a Krause & Becker airless sprayer
Forum topic by SweetTea posted 11-06-2016 11:15 AM 804 views 0 times favorited 3 replies Add to Favorites Watch
View SweetTea's profile
SweetTea
304 posts in 653 days
11-06-2016 11:15 AM
A buddy of mine recently gave me a Krause & Becker airless sprayer that he bought from Harbor Freight a couple of years ago. He used it to spray polyurethane on his cabinets. The problem is that although it powers on, it does not suck up material in the infeed tube, nor does anything come out the primer tube. There is no suction on the infeed tube.
I have tried pushing the button on the bottom of the machine that is supposed to unstick a sticky valve, but still no suction. I would probably venture to say that (knowing him) he didn’t clean it out all that well after using it.
Do any of you guys have any ideas on how I can get this thing working? Should I tear it apart and clean the inside real good? Is the pump serviceable and if so, how do I clean it?
3 replies so far
SweetTea
#1 posted 11-07-2016 10:45 AM
What would cause this thing to not have suction on the intake hose? How can I clean the pump on this thing?
Does anyone know if parts are available anywhere for a Krause & Becker airless sprayer from HF?
View Carloz's profile
Carloz
1147 posts in 584 days
#2 posted 11-10-2016 02:16 PM
Just get a new one on e-bay. It normally sells for $100. Fixing it would probably cost you more.
View lndfilwiz's profile
lndfilwiz
104 posts in 1593 days
#3 posted 11-10-2016 04:35 PM
Do you have the instructions with it? I had trouble with mine when it was new until I reread the instructions. There are some valves that need to be set in the suction position to make it work.
-- Smile, it makes people wander what you are up to.
