How would you make these legs?
« back to Joinery forum
Forum topic by huyz posted 11-06-2016 05:04 AM 1446 views 0 times favorited 23 replies Add to Favorites Watch
View huyz's profile
huyz
58 posts in 1063 days
11-06-2016 05:04 AM
Topic tags/keywords: bench miter joints bench legs legs joinery screws dowels
Hey all!
I’m trying to make this bench for indoor use:
For the legs, the tutorial uses miters, then uses brad nails and screws to join them as seen here:
Is there a simple, stronger way to make this than miters? I have a table saw, miter saw, drill, and router (no table) to use.
They also use screws to attach those legs to the bench top, which I’m also wary of. I was going to swap that for some dowels instead—is there a stronger, simple method you’d recommend?
Thank you for your yelp!
23 replies so far
View bigJohninvegas's profile
bigJohninvegas
516 posts in 1664 days
#1 posted 11-06-2016 08:01 AM
That design is ok, looks good anyway with the fact that it will hide all the end grain. Personally I would use a spline miter. That would give the joint plenty of strength.
http://lumberjocks.com/BigRedKnothead/blog/38806
I assume the bench is for outdoor use. I would use stainless steel screws.
-- John
View Ron Aylor's profile
Ron Aylor
2649 posts in 849 days
#2 posted 11-06-2016 11:50 AM
Multiple Mitered Slip Joint …
View Loren's profile
10477 posts in 3850 days
#3 posted 11-06-2016 12:04 PM
Butt joints and pocket screws where nobody looks.
Pocket screw holes can be freehanded with a
3/8” spade bit. Drill straight for a bit to get
the spade engaged in the wood and then
twist in the cut to the desired angle.
Of course you can get a pocket hole jig for
$20 or so.
I can badmouth pocket screws with the best of
them but they are the right fastener for a lot
of jobs when traditional joinery is too time
consuming.
View Nubsnstubs's profile
Nubsnstubs
1422 posts in 1932 days
#4 posted 11-06-2016 02:54 PM
Rabbet the verticals, cut the horizontals with the proper angle and screw them together at the top and bottom. Measure the thickness of the top and the thickness of the top horizontal bar, add them together, and purchase screws that are at least a 1/4” shorter. If you countersink the screws, take that into consideration before you get the screws. Drill the proper size pilot hole, attach the legs using good glue, and you’re good to go…............ Jerry (in Tucson)
View bondogaposis's profile
bondogaposis
5091 posts in 2553 days
#5 posted 11-06-2016 04:39 PM
Box joints will be the strongest. For mitered joints I would spline them to add strength.
-- Bondo Gaposis
View Woodknack's profile
Woodknack
12431 posts in 2582 days
#6 posted 11-06-2016 04:54 PM
Someone asked this question before about the same bench. Agree with Bondo, box joints are the way to go.
View huyz's profile
huyz
#7 posted 11-07-2016 10:42 PM
Thank you for all of the replies guys!
Clamping this trapezoid is going to be difficult no matter which method used right ? Splined miters would look cleanest but require making a separate jig—more difficult than a box joint jig I believe. I wonder if box joints will be visible once dyed black.
Might go for box joints, or butt joints with screws. Lots of things to consider while finishing up the top :)
View TheFridge's profile
TheFridge
10739 posts in 1688 days
#8 posted 11-08-2016 02:08 AM
- Rick M.
Ditto
Edit: a little glue and free fine sawdust cures almost all cracks. Especially if painted.
#9 posted 11-08-2016 02:34 AM
Those legs are totally a biscuit joiner type thing
from the days when they were the hot thing
in WW magazines. The joiner handles the
angles at a snap, etc… that’s another way
but you still have to mess with clamping
any way you do it. I still maintain pocket
screws and butt joints are the least fuss
(screws in end grain are weak fasteners) but
considering the scope of doing the whole
project, lavishing some care on the joints
only adds a bit of time.
Personally I think these sorts of designs are
weak and I’d prefer an added gusset inside
the leg frames. This stuff is typically design-school
output and young design students often haven’t
been observing furniture much before school
and have no repair experience. Just fyi…
I get asked to make school designs from time
to time and they are always problematical.
View DirtyMike's profile
DirtyMike
637 posts in 1104 days
#10 posted 11-08-2016 02:39 AM
with a welder.
View tblank's profile
tblank
62 posts in 3172 days
#11 posted 11-08-2016 05:00 AM
If the legs are to be paint grade, why not cut them out of a piece of plywood as a single unit. Lay them up to achieve desired thickness with epoxy. Edge band the visible edges and paint. Legs with no joints at all and still strong enough to bear required weight.
Craftsman on the lake
2832 posts in 3639 days
#12 posted 11-08-2016 06:34 AM
Make them without the 45’s. Just be sure the verticals overlap the horizontals so the end grain of the horizontal pieces don’t show from the sides. Then put two screws in each corner. Countersink them and plug with a wood dowel, chisel and sand off the extra. When painted they won’t show at all and it will be strong.
Screws will also be strong.
View huyz's profile
huyz
#13 posted 11-08-2016 07:05 AM
Thanks for the tips everyone.
I just wrapped my head around standard box joints for 90 degree angles, but for a trapezoid like this it gets more complex I think—how do you accomplish this? Also how would you clamp a trapezoid like this—a custom jig just for this project?
Kinda leaning towards butt joints to not overcomplicate this.
View huyz's profile
huyz
#14 posted 11-08-2016 07:07 AM
- tblank
Maybe I’m not understanding you right, but if it’s cut from a single sheet won’t it require multiple sheets, with tons of waste?
View MrUnix's profile
MrUnix
7050 posts in 2401 days
#15 posted 11-08-2016 07:25 AM
with a welder.
- DirtyMike
That was my first thought also… as soon as I saw it, I instantly thought rectangular metal tubing.
