Porter Cable PCB222TS blade height drops
Forum topic by WearyTraveler posted 11-05-2016 09:32 PM 389 views 0 times favorited 1 reply Add to Favorites Watch
View WearyTraveler's profile
WearyTraveler
4 posts in 846 days
11-05-2016 09:32 PM
Topic tags/keywords: question tablesaw porter cable pcb222ts
I bought it a couple of years ago. It worked fine for a while. Recently it’s started misbehaving.
Raising the blade is difficult. When cranking it up, it’ll go fine for a couple revolutions of the handle, then be difficult to turn the crank. After a few revolutions of the handle, it’ll get easy again. No problem when lowering the blade. It’s probably sawdust restricting the blade or motor. Is this something I can fix myself (I’m not very mechanical)?
The other issue is that the blade won’t remain at the height I set it. This isn’t a problem when ripping lumber, but when I’m trying to cut a groove on several boards the height of cut changes. I’m constantly nudging it back up. The result is a ragged groove requiring a bunch of chisel work.
1 reply so far
View Madmark2's profile
Madmark2
379 posts in 496 days
#1 posted 11-05-2016 10:39 PM
Try adjusting the wheel lock in the center of the blade height wheel.
M
