Best plane for highly figured woods?
« back to Hand Tools forum
Forum topic by BalsaWood posted 11-04-2016 08:34 PM 1705 views 0 times favorited 18 replies Add to Favorites Watch
View BalsaWood's profile
BalsaWood
36 posts in 1067 days
11-04-2016 08:34 PM
I’ve been working with highly figured woods and have always experienced tear out of some sort either from the jointer, planer, and jack plane. Even with light passes, tear out sometimes occurs. I’ve been looking at various planes to deal with the tear out- namely:
LN No. 85 scraper plane
LV low angle smoother with a 50 degree blade
The only planes I own now are a jack plane and block plane. I was thinking one of the planes mentioned above could be a good addition to help with tear out issues. Sometimes these are large surfaces I am dealing with. A glass smooth surface after planing is not something I care about either since I don’t mind sanding afterwards. Any suggestions?
18 replies so far
View newwoodbutcher's profile
newwoodbutcher
730 posts in 2759 days
#1 posted 11-04-2016 08:45 PM
No expert here, but I use a LN with high angle. I don’t work with a lot of wild figure or grain, but this works for me (failing that a scraper as my next choice). I’ve always thought a quality scraper plane would be the utlimate hand tool solution for wild wood. So.. I think I would go with the scraper plane. Either choice will be a great tool. I’ll be interested in this conversation.
-- Ken
9981 posts in 3557 days
#2 posted 11-04-2016 08:53 PM
Some German made planes are bedded at higher
pitches. http://www.thebestthings.com/newtools/planes_nt.htm
Also, awhile back Lee Valley was selling planes
made in Indonesia and I think they may have
had higher pitch angles for working tropical
hardwoods.
You can also try back beveling an iron in a smooth
plane by 5-10 degrees. It’s a fairly simple
and cheap experiment that changes the effective
working pitch of a plane.
Also, futzing with making your chipbreaker
setup as near to perfect as possible, set back
perhaps only 1/64” and polished to a mirror
finish, the chipbreaker will help with tearout.
That’s what they were invented for.
View TheFridge's profile
TheFridge
8908 posts in 1395 days
#3 posted 11-04-2016 08:56 PM
I don’t like BU planes because they don’t have a chipbreaker. I’d use them for endgrain. That’s about it.
I have a lie Nielsen 4-1/2 with 55 degree frog that will plane crotch walnut against the grain with no tearout.
The higher the angle, the harder the push but lower odds of tearout.
http://contrib1.wkfinetools.com/rittnerB/sUpCapIron/sUpCapIron-01.asp
The video on the link was eye opening.
View KelleyCrafts's profile
KelleyCrafts
2705 posts in 648 days
#4 posted 11-04-2016 09:02 PM
I have to agree with Ken. Most everything I work with is difficult. Arizona wood is all over the place and most of what I use is small stuff I mill myself or big stuff WoodyAZ on the forum here has milled. I have a bevel up smoother with 50 degree blade and it does well but still not perfect. My electric planer also doesn’t fit the bill well on everything. My next plane will be a scraper plane. I use scrapers by hand now and it works out well but it would be nice to have one in a plane.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
View unbob's profile
unbob
804 posts in 1812 days
#5 posted 11-05-2016 12:44 AM
I have some local walnut that is very hard to plane, on wider surfaces I use one of the larger planes with a radius ed blade, then smooth it with a #5 1/4 or #3, then scrape it. I am making a wood gun case out of wenge, the wood is fairly straight grained, but the grain reverses along with hard spots. I can plane it with narrow blades, or curved blades, then scraping it.
View Aj2's profile
Aj2
1273 posts in 1707 days
#6 posted 11-05-2016 03:16 AM
My best plane for difficult wood is the #4 Lie Neilson smoother standard angle.
If that doesn’t get done I will scrape with a card.
You don’t mention what this highly figured wood is that brought you to this question.
I have come up against some wood that cannot be planed so don’t beat your self up.
Aj
-- Aj
View HokieKen's profile
HokieKen
4625 posts in 1047 days
#7 posted 11-05-2016 04:05 AM
I use a # 4 as sharp as I can get it then follow it up with a cabinet scraper. Sometimes it takes a buncha scrapin though!
-- Kenny, SW VA, Go Hokies!!!
TheFridge
#8 posted 11-05-2016 04:19 AM
Whenever photobucket is back up and running I’ll post some pics of some swirly grain walnut planed with a LN with 55 deg frog. With and against the grain.
View Aj2's profile
Aj2
#9 posted 11-05-2016 04:26 AM
Whenever photobucket is back up and running I ll post some pics of some swirly grain walnut planed with a LN with 55 deg frog. With and against the grain.
- TheFridge
Walnut ? Too easy
-- Aj
View JohnChung's profile
JohnChung
398 posts in 1983 days
#10 posted 11-07-2016 03:30 AM
Not sure if you have the LAJ from Veritas. You can change the blade to 50 degrees. For smoothing
a #4 can work well WITH the chipbreaker very close to the edge.
If all fails then use a scraper plane.
TheFridge
#11 posted 11-07-2016 03:48 AM
Whenever photobucket decides to work (I’ve been waiting for days) I’ll post pics amboyna burl I planed. You’d be surprised.
It’s all about the chipbreaker.
View OSU55's profile
OSU55
1524 posts in 1898 days
#12 posted 11-07-2016 10:41 PM
High cutting angle, however you get there. Along with the LN high angle frogs, LV now has the custom hand plane line that allows selecting the frog angle anywhere from 40-65°. The LA BU smoother planes with high bevel angles work very well. LV’s scraper does a great job, review here. I have a Mujingfang 63° angle wooden smoother (2” wide blade) from japanwoodworker that works great, but you need to know how to tune it up. Lots of options – the Mujingfang is the cheapest at ~$70.
View 1deadeye's profile
1deadeye
5 posts in 837 days
#13 posted 11-07-2016 10:56 PM
I often use a card scraper on highly figured wood because of the ability to change direction quickly when the grain direction changes. It leaves a much nicer surface than sandpaper.
View rwe2156's profile
rwe2156
2804 posts in 1389 days
#14 posted 11-08-2016 01:59 PM
You can put a 5 degree back bevel on a bench plane to effectively raise the pitch. I have not done this but very respected people recommend it.
I generally go with the card scraper. Properly prepared nothing works better in for me.
Problem is no matter how much you practice on figured wood, you never know how a particular board is going to behave until you put the iron on it. And sometimes it becomes and “oops” moment.
View sawdustdad's profile
sawdustdad
354 posts in 794 days
#15 posted 11-08-2016 02:48 PM
Drum Sander and a hand scraper. That’s the lazy man’s approach. Count me as a member of the Norm Abram school of woodworking. If a power tool can do it, you don’t need the hand tool.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
