Disc sander problem
Forum topic by Sawdust2 posted 07-15-2010 12:45 AM 1024 views 0 times favorited 2 replies Add to Favorites Watch
View Sawdust2's profile
Sawdust2
1466 posts in 4261 days
07-15-2010 12:45 AM
Topic tags/keywords: question disc sander
Following right on the tail of and trying to prevent an accident.
I have a Delta 6×9 belt sander.
Couldn’t find 9” Delta discs so I got some Jet 8” discs. Would not stick to plate.
So I bought some 8” Delta discs. They won’t stick on the plate, either.
I’ve cleaned the plate with acetone. Still no stick.
Should I spit on it, look at it cross eyed, mumble voodoo?
2 replies so far
Rick Dennington
6239 posts in 3367 days
#1 posted 07-15-2010 01:16 AM
Greetings Lee, I have the same sander….6” x 48” belt, and a 9” discs.. I buy my 9” discs from Woodworkers Supply and belts ,too. They sometimes won’t stick either, so like you, I take some some lighter fluid and clean the platten. For me, lighter fluid works better… once dry, and if the new ones don’t want to stick good. then I spray them lightly with some kind of a craft glue (I forget the name) in a aersol can… that works. Go to woodworkers.com, and look under sanding discs, or abrasives… they have the 9” alumnium oxide, and zirconia alumina in all different grits….... Hope this helps a little…
-- " It's a rat race out there, and the rats are winning....!!"
35139 posts in 4574 days
#2 posted 07-15-2010 01:23 AM
Lee I think I’ve seen spray adhesive at Big orange and Big blue I think it’s 3M brand.
I used Lacquer Thinner to clean the surface.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
