Create a bed, Murphy bed
Forum topic by panamawayne posted 11-03-2016 01:42 PM 474 views 0 times favorited 3 replies Add to Favorites Watch
View panamawayne's profile
panamawayne
72 posts in 1512 days
11-03-2016 01:42 PM
Anyone have experience building a “Create A Bed?” I was wondering how many hours that it would take to make and install the bed and accompanying cabinets? I don’t have furniture grade plywood down here so it will be out of solid wood..
3 replies so far
View Runner's profile
Runner
65 posts in 826 days
#1 posted 11-03-2016 05:40 PM
It took me approx 4 months, but I’m a novice with basic tools. The rockler plan was spot on, which made the build easy enough. And the create-a-bed hardware is also very good.
-- Kjell - Eau Claire WI
View johnstoneb's profile
johnstoneb
2968 posts in 2226 days
#2 posted 11-03-2016 06:08 PM
It took me a couple of weeks of off and on. lot of it waiting on glue or finish to dry. The plan was good. measurements spot on. I ordered from amazon the hardware came from create a bed same hardware that Rockler has. Price was a little better.
-- Bruce, Boise, ID
View Lifesaver2000's profile
Lifesaver2000
555 posts in 3165 days
#3 posted 11-04-2016 02:20 AM
I built one of these several years ago which can be seen in my projects. Using all solid wood instead of plywood will be an entirely different undertaking. The instructions state that plywood is required for strength although there are instructions included to use particle board if I recall correctly. Using the included plans with all solid wood will result in some long cross grain joints that will require some reengineering. Depending upon the wood used there might be some challenges because of the change in weight.
