Tabletop question
Forum topic by MashMaster posted 11-02-2016 07:57 PM 559 views 0 times favorited 8 replies Add to Favorites Watch
View MashMaster's profile
MashMaster
134 posts in 2893 days
11-02-2016 07:57 PM
I am getting closer to gluing up the kitchen table that I am making progress on it. I want to make the breadboard ends but am trying to think of the right method for them.
I’m interested in your thoughts.
Options:
• Tongue and groove the full length (a ¾” tongue into a groove along the breadboard end. Tack center with peg tight, loose on the sides with pegs and their holes elongated.)
• Tongue and groove with mortises (a 1/4” tongue into a groove along the breadboard end. Put in five ¾” tenons evenly spread across the width. Tack center tenon, loose on the sides with pegs as the above option.)
• Sliding dovetail the full length. (This would seem to be the strongest but cutting the dovetail on the end of the table might be difficult to cut.)
• Loose tenons, put in loose tenons instead of cutting tenons into the table. Tack the center.
• Loose tenons with dowels, put in loose dowels instead of cutting tenons into the table. Tack the center. (This is probably easiest.)
Anything I am missing? What do you think?
-- - Dave ; Austin, TX
8 replies so far
View Mikenln's profile
Mikenln
13 posts in 1006 days
#1 posted 11-02-2016 09:13 PM
I would go for “Tongue and groove the full length (a ¾” tongue into a groove along the breadboard end. Tack and glue center with peg tight, loose on the sides with holes elongated parallel to end.)”.
I might try a sliding dovetail on a utility table for practice but not where the result was important to me.
View pottz's profile
pottz
3805 posts in 1218 days
#2 posted 11-02-2016 10:57 PM
id go with option one as well,i used this method on a top for a greene and greene wall table and it worked fine.
View Carloz's profile
Carloz
1147 posts in 825 days
#3 posted 11-02-2016 11:11 PM
Your miter gauge or whatever you used to cut the boards to length is not set accurately and it shows. You need to trim the ends now with a track saw/hand plane/sander,
MashMaster
#4 posted 11-02-2016 11:18 PM
- Carloz
Yeah those were rough cut. I will clean up the cuts when joining them at glue up for the boards that are parqued with two boards to make a full length plank. Then after glue up, i will trim the edge since they will most likely shift some during glue up.
View pintodeluxe's profile
pintodeluxe
5815 posts in 3047 days
#5 posted 11-02-2016 11:31 PM
I use a router and jig to mill the tenon on the tabletop, then cut a deep stopped groove in the breadboard end.
Here is how I go about it… http://lumberjocks.com/pintodeluxe/blog/31777
Make the tenons nice and long for a strong joint.
View sras's profile
sras
4964 posts in 3363 days
#6 posted 11-03-2016 01:34 AM
What Willie said.
I remember reading here about a table with a breadboard end that failed. Turns out an exceptionally heavy man always sat at the end and bore his full weight on the breadboard every time he stood up.
Long tenons.
MashMaster
#7 posted 11-03-2016 02:17 AM
Thanks for all the input, I appreciate it. I wonder if I do loose tenons, I can make the pretty darn long. That might be the strongest option.
View rwe2156's profile
rwe2156
3225 posts in 1714 days
#8 posted 11-03-2016 02:16 PM
Options:
- MashMaster
I think this is the best option but I would increase the groove depth to 3/8 and make the tenon depth 1 1/4”. I would make the groove 3/8” wide.
Loose tenons would also work.
