Solid wood vs Plywood Panels?
Forum topic by trevor7428 posted 11-02-2016 07:19 PM 1895 views 0 times favorited 28 replies Add to Favorites Watch
View trevor7428's profile
trevor7428
266 posts in 1166 days
11-02-2016 07:19 PM
Chest
P
So i want to make this Chest, found in Woodsmith Magazine. The plan calls for solid wood panels. Trying to keep lumber costs down. I was thinking of plywood panels instead. Would anyone recomend this. Or should i do it right and use solid wood?
Im planing on using Cherry for the Rails and Stiles. So if i used plywood, i would try to find some cherry plywood. I just figured, since the panels are flat (not a raised panel) it shouldnt look that different between Cherry Plywood or Cherry solid wood panel.
What do you guys think?
BTW, ive never used Cherry before. Is it hard to work with or recommended for this kind of project?
-- Thank You Trevor OBrion
28 replies so far
View splintergroup's profile
splintergroup
2437 posts in 1428 days
#1 posted 11-02-2016 07:37 PM
Plywood would work fine! Be ready for sticker shock however!
For a project of that size, I’d worry about the finish (blotching, etc), so read up!
As to workability, I love cherry! The only real ‘bummer’ is how it has a tendency to burn from router bits and saw blades.
Best countermeasure is to cut 1/16” oversize and make the finally cut a skim cut.
View JayT's profile (online now)
JayT
5962 posts in 2417 days
#2 posted 11-02-2016 07:44 PM
Yep, plywood probably won’t save you much money. Around here, 3/4 cabinet grade hardwood plywood runs about $100-120 per sheet. It will, however, be a lot more stable, so you don’t have to worry so much about allowing for wood movement on those panels.
On a project that size, many people, including me, might want to use plywood for the panels because of that. And while plywood may not save a lot of money, it would save quite a bit of time not having to glue up and flatten all the solid wood.
View gargey's profile
gargey
1013 posts in 981 days
#3 posted 11-02-2016 07:44 PM
Cherry is very nice to work with, IMO. All of my experience is with hand tools.
Plywood would be indistinguishable from solid wood. The veneer might not match your solid boards, the same way your solid board might not match your other solid boards, however. So pay attention to that. Buy the plywood first…
View Mosquito's profile
Mosquito
9543 posts in 2498 days
#4 posted 11-02-2016 07:45 PM
I agree with the above.
I have only worked cherry by hand, though, so not had any issues with burning.
Also, you might be surprised at how much a hardwood veneered plywood costs compared to big box store cheap plywood…
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
trevor7428
#5 posted 11-02-2016 08:49 PM
For a project of that size, I d worry about the finish (blotching, etc), so read up!
As to workability, I love cherry! The only real bummer is how it has a tendency to burn from router bits and saw blades.
- splintergroup
To be honest, i havnt even thought about the finish lol. So thanks i look into that.
But speaking of finish, what do you recomend? Just a water based clear coat?
Im not the beat with finishes.
Thanks everyone for the advice
View jmos's profile
jmos
902 posts in 2575 days
#6 posted 11-02-2016 08:51 PM
Another option is to use inexpensive plywood or MDF for the panels and veneer them. I recently made a similar chest and did just that. It’s a good starter project for veneering since the panels are relatively small and easy to deal with. You can pick a really nice veneer and get a different look for not much more. You could also compare the cost of getting cherry veneer and making your own cherry plywood; in this case, since you probably won’t need a full sheet, it may be cheaper to veneer your own.
I really like working with cherry, but it is prone to blotch if you stain it. My solution is not to add any color to it at all; it’s a bit pale initially, but over time it develops a great color all by itself.
-- John
View jmos's profile
jmos
#7 posted 11-02-2016 08:53 PM
I also have to throw out that, for the amount of time you’ll invest in the project, the cost of lumber is small change. I’d encourage you to get what you think will look best; the cost only hurts once and you’ll have the project for years and years.
-- John
splintergroup
#8 posted 11-02-2016 09:34 PM
My guess is the panels will be 1/2” thick (or less)? Still pricey, but follow the advice of seeing the color/grain of the plywood first so you can try and find boards that match.
Clear finish is popular with cherry for the blotching reason. If you don’t have to try and blend in sap wood to match, clear whatever (oil/water based, even shellac) is easy enough. Remember that cherry darkens quite a bit when exposed to sunlight, I always try to ‘pre-sun darken’ anything I make out of cherry for that reason.
View Carloz's profile
Carloz
1147 posts in 797 days
#9 posted 11-02-2016 10:50 PM
If you are like me, by the time you finish it you spend so much efforts that the price of material becomes irrelevant. Every time I cheap out on wood I regret it by the end of the project. IMHO you should only try to save on material when you are in production making the same thing all the time.
View 8iowa's profile
8iowa
1587 posts in 3967 days
#10 posted 11-02-2016 11:29 PM
I just finished a large ‘Shaker style’ wardrobe in cherry. The door panels are re-sawn and bookmatched solid wood. It was a lot of work, but the effect is worth it. For the back I used 1/2” cherry plywood, mainly for the added strength. The 4×8 sheet of plywood cost over $100. It was a special order and very high quality.
To help avoid burn marks in Cherry I recommend a 24 T blade for ripping and then change to a 60 T blade for my crosscuts. I also run my saw (Shopsmith) at about 2500 rpm. Burn marks are very difficult to remove.
View HokieKen's profile
HokieKen
7190 posts in 1344 days
#11 posted 11-02-2016 11:31 PM
As said above, ply isn’t likely to save any $ but will save some time since you can skip the panel glue ups. If it were me, I’d go solid wood. Cherry is great to work with so I wouldn’t be too aprehensive about that. Like JayT said, ply is more stable so that should weigh into your decision as well.
-- Kenny, SW VA, Go Hokies!!!
View BobAnderton's profile
BobAnderton
283 posts in 2996 days
#12 posted 11-03-2016 01:27 AM
Usually, in my opinion, it’s obvious when hardwood veneered plywood is used for panels instead of solid wood panels because the grain pattern is all wrong. Even quartersawn plywood where the surface veneer isn’t rotary cut looks different than solid wood in the same piece because it finishes differently. That said, I’m no professional, so if someone who does this for a living says it can be done and look great then I’d believe them, just relaying my experience.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View bbasiaga's profile
bbasiaga
1240 posts in 2201 days
#13 posted 11-03-2016 02:11 AM
For a cherry finish, I like just some natural danish oil, topped with Arm R Seal. I have seen a project where the danish oil was replaced with garnet shellac, then the Arm R Seal….it looked great too. I plan to try that next time.
Bob is right, the plywood grain will look different than solid wood. But that doesn’t mean it looks bad.
Brian
View Aj2's profile
Aj2
1886 posts in 2003 days
#14 posted 11-03-2016 05:15 AM
I also agree with bob, plywood is going to have a different look.And you really don’t know until you have a finish on it.
There’s always the risk of a dent or scratch when it’s new or later in life that really diminishes the piece.With solid wood it will just add character.
It’s a really nice looking piece.With or without plywood will call any craftsman to do his best.
Good luck
Aj
-- Aj
5179 posts in 2699 days
#15 posted 11-03-2016 11:04 AM
To echo much of what has been said: cherry ply actually cost me more than solid wood most times. I still prefer it for panels, it removes some of the conventions you have to use for wood movement. I would use plywood on that chest, personally. As for finish, the last thing I would do is just apply a waterborne topcoat. They are fairly colorless, and do nothing to enhance the grain. But a coat of garnet shellac, followed by that same waterborne is very nice, and quite durable if it’s a quality waterborne. Using it under a waterborne, I would suggest you get dewaxed shellac (it is available in garnet).
showing 1 through 15 of 28 replies
