Bolting method for workbench top
Forum topic by groland posted 07-14-2010 02:34 PM 2083 views 0 times favorited 4 replies Add to Favorites Watch
View groland's profile
groland
212 posts in 3651 days
07-14-2010 02:34 PM
Hi,
I have finished my workbench base and am now thinking about how to attach the top. The top is finger-joint laminated ash 2 3/4 in. thick. The trestle member it sits on is 3 3/8 in. thick for a total thickness of 6 1/8 in.
I am thinking of using 1/2 in. machine bolts and nuts with flat washers to attach the top. The flat washer and bolt head will be recessed into the table top.
I will probably bore 5/8 in. holes for the machine bolts for easy manipulation.
My concern is to allow for expansion of the top. What I am thinking about is to have normal 5/8 in. holes in one trestle, probably the one near to my front vise and, at the far trestle, having an opening about 3/4 – 1 in, a slot, for the bolts so the top can expand and contract.
That would mean the recess in the top that takes the recessed bolt and washer would have to be wider than normal and the bolt hole would too.
I guess I have the following questions.
1.) Is this a reasonable way to go about this, or is there a better/standard method I ought to consider?
2.) Do I need to allow for this much expansion—more or less? (The top is ash boards, ca. 1” thick, finger-jointed end-to-end and glued up into a 2 3/4 in. thick slab.
3.) What would be the best method(s) to do the boring for the expansion bolt hole? (I’m assuming I could use a Forstner bit to bore the recess holes side-by-side. What’s a good method to bore the 5/8 W X 3/4 to 1 in long bolt slot?
Thanks,
George
View antmjr's profile
antmjr
262 posts in 3423 days
#1 posted 07-14-2010 03:46 PM
I concur with DaveR. I have a little bench, built by an Austrian firm many years ago; the top wasn’t fastened, it has only two wooden pins, and although it’s not as heavy as yours probably is, it is very steady (and comfortable to move)
other pics here on my picasa album
-- Antonio
groland
#2 posted 07-14-2010 04:28 PM
Thanks to DaveR and antmjr!
So you guys have top fastening methods that make no provision for expansion/contraction of the tops?
Are your tops laminated or solid lumber? I guess expansion/contraction has not been a issue for you?
Many thanks,
George
groland
#3 posted 07-14-2010 05:15 PM
DaveR,
Ah thanks. I needed to read more carefully! I understand now what you mean. Thanks!
George
antmjr
#4 posted 07-14-2010 06:05 PM
(I have canceled everything, because I’m not sure of what I wrote)
-- Antonio
