a cheap twist on detail sanding
Forum topic by schloemoe posted 07-14-2010 04:39 AM 1533 views 0 times favorited 14 replies Add to Favorites Watch
View schloemoe's profile
schloemoe
709 posts in 2839 days
07-14-2010 04:39 AM
You know how when you’re doing something really intricut and you get that one spot that comes up to an inside point and It just does not look right to you. So then you go off in search of the right tool to sand it with you can use dowels with self adhesive sand paper even thin strips of wood with self adhesive sand paper or you can go buy a profile sander which cost $$$$ I don’t know and then you stand the risk of ruining you work piece if you’re not careful. I’ve stumbled across a very inexpensive alternative ! You know those finger nail files you’re wife probly uses? You know the ones made out of styrofoam and they are abrasive on both sides.ya ya thats it thats the one.You can buy those 3for $.99 like at Walmart they won’t take alot of abuse but they do work very nicely.I ve been using them on and off for about a year and they work fine and they’re so cheap it doesn;t matter if you loose a couple now and then. How many of you have found a cheap alternative to an almost dailey problem I’d be interested to hear…......................Schloemoe
14 replies so far
13594 posts in 3243 days
#1 posted 07-14-2010 04:46 AM
use them myself ,
they do the job !
116900 posts in 3479 days
#2 posted 07-14-2010 04:46 AM
Yes they work great Rick thanks for sharing.
View Bob Collins's profile
Bob Collins
2486 posts in 3585 days
#3 posted 07-14-2010 04:47 AM
Thanks for sharing that one, have never given something simple and inexpensive like that a thought. Would also like to hear of others which members have come across.
-- Bob C, Australia. Your best teacher is your last mistake.
View Boris 's profile
Boris
190 posts in 2817 days
#4 posted 07-14-2010 04:58 AM
thank you for the tip
View lew's profile (online now)
lew
11939 posts in 3657 days
#5 posted 07-14-2010 05:11 AM
ssshhh…. Mimi keeps blaming the dog for chewing hers up ;^)
schloemoe
#6 posted 07-14-2010 05:16 AM
I don’t have a dog to blame it on but I do have a couple of cats …Yeah that’s the ticket….....Schloemoe
View lanwater's profile
lanwater
3111 posts in 2836 days
#7 posted 07-14-2010 06:16 AM
I have few in the shop that I commandeered from upstairs.
they came handy on a couple of occasions.
Thanks for sharing.
-- Abbas, Castro Valley, CA
View Bob Kollman's profile
Bob Kollman
1798 posts in 3092 days
#8 posted 07-14-2010 07:42 AM
My wife sometimes wounders where they all went?
-- Bob Kenosha Wi.
View docholladay's profile
docholladay
1287 posts in 2960 days
#9 posted 07-14-2010 10:13 AM
I prefer the ones called emory boards. They are even cheaper. They are a little stiffer and they hold up better and yes, they work quite well. I always have a few on my bench handy for use.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View sedcokid's profile
sedcokid
2729 posts in 3500 days
#10 posted 07-14-2010 02:00 PM
Good idea!! Thanks for the tip….
-- Chuck Emery, Michigan,
View WoodArtbyJR's profile
WoodArtbyJR
428 posts in 2866 days
#11 posted 07-14-2010 03:37 PM
I was digging around in the upper shelves of my shop yesterday and saw an old bucket of foam rubber sheet rock sanding blocks (different shapes and sizes) and thought that I should otta try them for sanding on creviced items. Well, with your affirmation on the nail board I know these will work so I guess I will have to climb back up there and bring them down to working level and give them a try. Thanks Rick
-- Jim Roberts, Port Orchard Washington
View Jonathan's profile
Jonathan
2608 posts in 2952 days
#12 posted 07-14-2010 06:15 PM
Along roughly the same lines, I have used a square of sandpaper, wrapped partially around your basic Bic white-barreled ball point pen. It seems to be just the right size for sanding after the use of a cove bit in the router. Just make sure to take the cap off.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
23537 posts in 3753 days
#13 posted 07-15-2010 02:45 AM
Been there, done that. Anything that works is good enough in my book.
View Michael's profile
Michael
201 posts in 2899 days
#14 posted 07-16-2010 05:19 AM
thanks a lot, i’m going to break into my x-girlfriends house now
-- "A woodworking project is either a masterpiece or a POS" Dr. Lang
