Router Table Miter Gauge... how the heck..
Forum topic by Shay posted 321 days ago 498 views 0 times favorited 4 replies Add to Favorites
View Shay's profile
Shay
45 posts in 329 days
321 days ago
Topic tags/keywords: question router
I feel like such an amature right now.
I got a new Router Table which I mounted on my Jet table saw, only to realize it didn’t have a miter gauge slot. So, I picked up a gauge track, cut the slot with my router and mounted the track. It was only then that I realized all my cheap miter gauges were smaller non-standard gauges. I have a sliding table gauge for the table saw so I hadn’t invested in anything better.
I came on here today to get some opinions on gauges when I saw posts saying they never use the miter gauge track on their router table. Well.. I’m stumped on how you get by without it. I use my router table for drawer corners and stiles. Without the miter gauge to keep the piece straight I can see problems like chipout. Is there a better solution that I’m missing?
Thanks,
BlackNoir
-- Centerville, MN - Hobbyist and DIYer
Douglas Bordner
2708 posts in 592 days
321 days ago
I register against the fence and push through the cut with a sacrificial backing board.
View Peter O's profile
Peter O
669 posts in 403 days
321 days ago
I use sleds that register against the fence or against the edge of the table. But lots of guys do use a slot, it’s just a matter of preference. You already have the slot, so you could build a sled or gauge that uses it – just cut a strip of hardwood to fit.
-- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com
View Mark Mazzo's profile
Mark Mazzo
294 posts in 441 days
321 days ago
I would second Doug’s approach. I never use a miter gage on my router table – just back the piece with a square piece of scrap MDF or such and register it against the fence. This also has the advantage that the backer can act to lessen any possible chip out you may experience.
View coloradoclimber's profile
coloradoclimber
345 posts in 596 days
321 days ago
Pretty much Douglas has it. Usually I make a jig / push block and register against the fence. The push block can be as simple as a squared up 2×4, one face against the workpiece (holds the workpiece square and acts as the backer board to help prevent tearout) and one face against the fence to hold everything square as you pass the bit. If you have a longer workpiece and you’re cutting the short end, like a drawer side, it works easier to make a square of 3/4 ply or mdf maybe 12×12 and screw a handle to it. Basically you’re making a gauge that registers against the fence instead of a slot.
Bookmark And Share This Page
