Building a dinning table without using breadboard ends?
Forum topic by SweetTea posted 10-31-2016 03:35 PM 1116 views 0 times favorited 4 replies Add to Favorites Watch
View SweetTea's profile
287 posts in 594 days
10-31-2016 03:35 PM
Hey guys, I am looking to branch out my capabilities from cabinetry to furniture. I would like to start out with a table, perhaps a small-ish retangular dinning room table. I have seen so many people do the farm house style with the top having breadboard ends, but for my first table, I don’t want to do breadboard ends.
Now I have glued up many panels in my life, mainly for making raised panel doors, but never a table top. my table will have a top that is 75” deep by 42” wide. i plan to use maple cut into 3” wide strips and glue them together after running them through the jointer like I normally would for door panels.then cut the top to its final size before the planing and sanding procedures begin. My questions are
Does the top need any special pieces to installed on the ends? (Where the breadboards would normally go) or can I leave the ends exposed? (My preferred choice would be to leave them exposed.) i
View martyoc's profile
40 posts in 851 days
#1 posted 10-31-2016 04:01 PM
I have built several tables using walnut and maple without using separate end boards. I used a seal coat of dewaxed shellac to the entire piece, in part to seal the end pores, before applying the final finish and the ends came out just fine. This avoids any issues that may arise from seasonal expansions as well as simplifying the construction.
-- Marty O'C
View Woodknack's profile
11311 posts in 2314 days
#2 posted 10-31-2016 04:20 PM
I’ve built six tables and none have breadboard ends, they are completely optional although I would consider them if doing a long trestle.
-- Rick M,
View AlaskaGuy's profile
3985 posts in 2243 days
#3 posted 10-31-2016 04:32 PM
No need for BB ends. If you have good kiln dried lumber I wouldn’t rip to 3 inch prices. I never done that in 50 years and don’t have problems. And if I didn’t have good wood I wouldn’t be building at table. Just me
The less pieces the less work and easier to match the grain and color of the wood.
View bondogaposis's profile
4638 posts in 2285 days
#4 posted 10-31-2016 04:51 PM
No, you don’t need anything on the ends and yes you can leave the end grain exposed. I have done it many times and in many cases I prefer the look of exposed end grain over breadboard ends.
-- Bondo Gaposis
