First Outdoor Piece
Forum topic by swilly posted 10-31-2016 02:06 PM 318 views 0 times favorited 6 replies Add to Favorites Watch
View swilly's profile
2 posts in 503 days
10-31-2016 02:06 PM
Topic tags/keywords: outdoor finish sealant polyacrylic woof pine
Good morning!
I’m relatively new to the woodworking world, mainly building simple furniture for myself and close friends. But I am always looking to learn and get better, so I thought I would join the forum. Finishing has proven to be my biggest struggle.
I decided to build a set of Adirondack chairs for my backyard. I stained the chairs they desired color and slapped a coat of polyacrylic on it without thinking. I have since read that polyacrylic will not be good in outdoor applications. It will turn cloudy and lose adhesion. Can I lightly sand this coat of poly acrylic, and put a clear water sealant over it? Is there a clear outdoor water sealant with a matte finish?
Thanks in advance for your help!
View Snipes's profile
163 posts in 2175 days
#1 posted 10-31-2016 02:11 PM
Enjoy your chairs until it comes off.
-- if it is to be it is up to me
View johnstoneb's profile
2816 posts in 2103 days
#2 posted 10-31-2016 02:15 PM
x1 snipes. Enjoy them then when finish colors or lifts sand down and try another. Outdoor projects are extremely difficult to finish. The sun is hard on any finish you use.
-- Bruce, Boise, ID
2 posts in 503 days
#3 posted 10-31-2016 03:17 PM
Thanks for the responses.
Luckily, I only put polycrylic on one chair before I thought better of it. What would your recommendation (product) be for the others at this point? And should I go ahead and scuff up the polycrylic and use this product over it on the one chair?
Thanks again!
View Carloz's profile
1147 posts in 522 days
#4 posted 10-31-2016 03:49 PM
Spar varnish is usually go to finish for outdoor furniture. If you leave in coastal areas look at some boat supply places what they can suggest. Their stuff is more expensive but of very high quality.
View HerbC's profile
1727 posts in 2790 days
#5 posted 10-31-2016 07:38 PM
ANY film finish, including spar varnish will fail (fairly quickly) if exposed to outdoor environment. Penetrating oil finishes will last longer but will require regular maintenance but at least they don’t fail by peeling off the surface like varnishes.
Paint is one of the most durable finishes and protects the wood. And you can use any colors you like…
Good luck!
Be Careful!
-- Herb, Florida - Here's why I close most messages with "Be Careful!"
#6 posted 10-31-2016 08:29 PM
personally I would not use a varnish at all. Either let it weather or siding type finish(sikkens for example).
