any idea how to create this concave depression
Forum topic by rizzo posted 10-31-2016 01:12 AM 2889 views 1 time favorited 25 replies Add to Favorites Watch
View rizzo's profile
rizzo
68 posts in 1399 days
10-31-2016 01:12 AM
Topic tags/keywords: how to concave router technique
It seems so perfect that there is no way it was hand carved.. I saw this and I can’t figure out how i would do it. Any guesses on how this might be done. I just think it is really cool.
25 replies so far
View sras's profile
sras
4883 posts in 3276 days
#1 posted 10-31-2016 01:34 AM
A small power grinder could work for this…
View TheFridge's profile
TheFridge
10340 posts in 1633 days
#2 posted 10-31-2016 05:34 AM
Looks like a spokeshave.
View Mikesawdust's profile
Mikesawdust
327 posts in 3186 days
#3 posted 10-31-2016 09:18 AM
my guess would be a drill press with a special bit
-- You never cut a piece to short, you are just prepping that piece for a future project
View Tony_S's profile
Tony_S
924 posts in 3230 days
#4 posted 10-31-2016 09:54 AM
It’s made by these guys in L.A.
http://www.thewoodenpalate.com/
From what I can tell, it’s at least started with an angle grinder. Probably scrapers and sanders after that.
http://the-wooden-palate.myshopify.com/pages/inside-the-woodshop
Ive seen some of their products personally….very nice….very expensive.
This is a retailer in Calgary here.(only one in Canada)
http://shop.lemonceillo.com/search/results?q=walnut
All that said, I’ve made about a dozen of them. A router and a template works fine with a lot of scraping and sanding afterwards. CNC worked better, especially for the round bottom….still a fair amount of sanding involved.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View Cooler's profile
Cooler
299 posts in 990 days
#5 posted 10-31-2016 02:24 PM
- Mikesawdust
Yes, “convex drill bits”. I’ve never used one, and I’ve only ever seen them in pictures. Plus they look like they would be ungodly expensive.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=convex%20drill%20bit
Perhaps a really large spade bit could be re-ground to make this shape.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
View GR8HUNTER's profile (online now)
GR8HUNTER
4730 posts in 860 days
#6 posted 10-31-2016 02:32 PM
bowl bit ???
View Greg the Cajun Wood Artist's profile
441 posts in 1089 days
#7 posted 10-31-2016 02:32 PM
A core box router bit will do it…but the largest diameter I have seen is 2”
-- Wood for projects is like a good Fart..."better when you cut it yourself"
View jbay's profile
jbay
2678 posts in 1046 days
#8 posted 10-31-2016 02:53 PM
Probably done with a rosette cutter.
It would be pretty easy to have a knife cut for one of these,
if you were going to do enough of them to make it worth it.
View Loren's profile
10477 posts in 3795 days
#9 posted 10-31-2016 03:18 PM
Lotta sanding. You can get curved rubber sanding
“drills” you would glue sandpaper to.
In terms of the carving, die grinders, etc… skill.
The dish could be roughed out then the sides
defined with a large core box bit and a template.
I would use an overarm router and I suspect that’s
what they used for all the carving, using a template
made to follow the edge and a big coving bit.
View Jack Lewis's profile
Jack Lewis
326 posts in 1225 days
#10 posted 10-31-2016 03:21 PM
That was offset mounted on a large lathe. Betcha!
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View rick1955's profile
rick1955
264 posts in 1578 days
#11 posted 10-31-2016 05:34 PM
View JAAune's profile
JAAune
1838 posts in 2464 days
#12 posted 11-01-2016 02:06 PM
I think it’s possible to make a router jig that tilts in two directions and cuts that shape.
Jack Lewis could be right about the offset mount but it would require a massive lathe or one that has very slow RPM.
If I had to make just one and needed it perfect, I’d cut most of the scoop with a die grinder then sand it smooth with a half-sphere sanding block creating on the lathe.
View DrDirt's profile
DrDirt
4464 posts in 3889 days
#13 posted 11-01-2016 02:26 PM
The company likely just sets up a CNC and says give me a depression 4 inches across and 1.7 inches deep..then just hit ‘Enter’
View Ripper70's profile
Ripper70
1135 posts in 1056 days
#14 posted 11-01-2016 03:45 PM
rizzo
#15 posted 11-01-2016 04:04 PM
Thanks so much everyone! lots of great ideas and things to try! I really appreciate it. I also came across this video, which seems like a pretty cool method / too-build.
https://vimeo.com/52774678
