Outdoor glider pivot points
Forum topic by Ivan posted 07-12-2010 09:07 PM 1989 views 0 times favorited 9 replies Add to Favorites Watch
View Ivan 's profile
Ivan
185 posts in 3375 days
07-12-2010 09:07 PM
Topic tags/keywords: question
All,
I am trying to figure out what would be the best option for ‘axles’ on an outdoor glider.
I think that a bolt would not offer enough support and would wear the hole in the wood out of round, possibly elongating it and making the chair not glide smoothly.
Am I over thinking this? I wanted to try my hand at a glider, the though of 2 pipes nested seems to work in my mind, but the use of bearings seems excessive.
Thoughts??
-Ivan
-- "Do it right the first time, you'll just kick yourself later..."
9 replies so far
View rance's profile
rance
4258 posts in 3158 days
#1 posted 07-12-2010 09:34 PM
If you’re hung up on using wood, try Lignum Vitae.
Ivan
#2 posted 07-12-2010 09:46 PM
I’m planning on using scraps and was hoping to get by with 2×4’s for the frame. Basically I’d like to work out the details and not spend a ton of cash on something that will be left outside.
View ddockstader's profile
ddockstader
155 posts in 3259 days
#3 posted 07-12-2010 10:28 PM
Just get some nylon bearings from your local ACE hardware that fit over your bolts. These are nylon tubes about 1/2” bigger in diameter than the bolt. They are fairly cheap and will protect the wood. Make it glide better, too. Make the bolts long enough so the wood members don’t rub against each other and put 3 or 4 washers on the bolts between the wood pieces to hold them apart. Unless you weigh 1000 lbs, bolts alone would probably last 5 years. With the nylon bearings, you should get 10 years at least (providing you paint it).
rance
#4 posted 07-13-2010 02:43 AM
I guess it should be stated that the bearing part of the bolt should NOT have threads. Threads would quickly eat up most any material besides metal. An metal wouldn’t last as long as it would if it was designed properly.
View vicrider's profile
vicrider
179 posts in 2896 days
#5 posted 07-13-2010 03:01 AM
You might try these…
“Glider Bracket Hardware”: http://www.rockler.com/product.cfm?page=10550&filter=glider%20hardware
-- vicrider
rance
#6 posted 07-14-2010 01:16 PM
If you want bearings and want to build your own brackets, inline skate bearings can be had on ebay for less than 50 cents each. Get the sealed ones though.
Ivan
#7 posted 07-14-2010 04:24 PM
Rance,
Thanks, I was thinking they might work well. I’ll check.
-Ivan
View ratchet's profile
ratchet
1391 posts in 3785 days
#8 posted 12-27-2010 06:13 PM
Did you ever find a solution? It would seem to me that bronze bushings might be good solution over nylon.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3181 days
#9 posted 12-27-2010 06:33 PM
You could trying counter boring the pivot points and install bronze or brass shoulder bushings with stainless through bolts. they would be a lot cheaper than bearings and wear practically forever.
Sorry Ratchet you already said that. Great Minds Think Alike!
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
