Do I have a problem with a partially hand planed surface?
Forum topic by mbs posted 10-30-2016 02:28 AM 601 views 0 times favorited 4 replies Add to Favorites Watch
View mbs's profile
mbs
1657 posts in 2991 days
10-30-2016 02:28 AM
I put a coat of minwax wipe on poly on a sanded mahogany panel. Then I glued a edge on the front of the panel that was intended to be flush with the top. I had a very slight mismatch of the two surfaces so I pulled out my hand plane and made them flush. I hand sanded the planed surface a little bit then applied another coat of finish.
When I look a the surface, I can tell a distinct difference between the planed area and the sanded area. I’m not sure if its because there is an additional coat of finish on the sanded area. Should I sand it down or keep applying finish?
-- Sorry the reply is so long. I didn't have time to write a short reply.
View Carloz's profile
Carloz
1147 posts in 642 days
#1 posted 10-30-2016 03:59 AM
Of course it will be different. I assume you sanded to some normal grit like 150-220. Hand planes give much smother surface than that. Besides if you look under a microscope you will see that the sanded surface it torn with lots of fibers sticking out while the planed surface is evenly cut ( depending how good you are with the plane). The sanded surface is going to take the coat better.
If you tried to stain it the result would be disastrous.
View mbs's profile
mbs
#2 posted 10-30-2016 04:03 AM
I hand sanded the planed area with 220 just to scuff it up a bit. I didn’t stain it – just applied the wipe on poly. Are you suggesting I sand it down to bare wood?
Carloz
#3 posted 10-30-2016 04:29 AM
Nothing wrong with sanding it down. In fact I sanded off all the stain and clear coat from a table top recently 5 times ! Before I got it right.
View mbs's profile
mbs
#4 posted 10-30-2016 05:30 PM
I sanded the entire surface down. It only took 2 hours and looks good.
thanks for the comments.
