Cutting board glue jig
Forum topic by Tom posted 10-29-2016 04:09 AM 1934 views 0 times favorited 5 replies Add to Favorites Watch
View Tom's profile
Tom
178 posts in 1207 days
10-29-2016 04:09 AM
I saw this http://lumberjocks.com/projects/275578 today and it made me think about making one for my upcoming cutting board building projects. It seems to be very good for assembly/clamping…but it only does one at a time and I’ll be doing more than that. I was thinking of a smaller version…maybe 12” wide. big enough to assemble and clamp the board then add regular clamps to the ends of the board, remove, then add a center one while it drys. It seems like a good idea…but sometimes my ideas sound good to me but don’t work well in reality. I’m trying to minimize planing/sanding when I’m done and figure that I can get one “flat” side on the boards with and thickness variance on one side.
Good idea or bad?
5 replies so far
View UncannyValleyWoods's profile
UncannyValleyWoods
542 posts in 2010 days
#1 posted 10-29-2016 12:16 PM
That thing looks like a major pain in the ass and I think all the squeeze out is going to make that thing a nightmare.
I make a ton of cutting boards. Typically, I use the bar clamps themselves as the clamp rest, but I’ve also seen a great solution that is super simple and effective… Basically, you just take two lengths of PVC, create a cradle to keep them stable, then use those as clamp rests…You then do all of the clamping from the top… I’ve thought about throwing that together, but honestly, it’s just easier to glue on top of my bars and then scrape the bars after the glue is dry.
I think the thing you linked to will be a giant headache and a waste of time. IMHO…
-- “If Jesus had been killed twenty years ago, Catholic school children would be wearing little electric chairs around their necks instead of crosses.” ― Lenny Bruce
View HorizontalMike's profile
HorizontalMike
7770 posts in 3060 days
#2 posted 10-29-2016 12:33 PM
I make a ton of cutting boards. Typically, I use the bar clamps themselves as the clamp rest, but I ve also seen a great solution that is super simple and effective… Basically, you just take two lengths of PVC, create a cradle to keep them stable, then use those as clamp rests…You then do all of the clamping from the top… I ve thought about throwing that together, but honestly, it s just easier to glue on top of my bars and then scrape the bars after the glue is dry.
- UncannyValleyWoods
I use blue painter’s tape on the bars of the clamps so I don’t have to scrape the bars clean. Learned this after having had to scrape so many of the clamp bars over time… ;-)
View William Shelley's profile
William Shelley
587 posts in 1616 days
#3 posted 10-29-2016 03:43 PM
Keep in mind that black iron pipe that most people use for pipe clamps will stain wood when a water-based glue is used. If you’re using galvanized pipe or normal bar clamps with a chrome/zinc finish obviously this isn’t an issue.
-- Woodworking from an engineer's perspective
View CopperTree's profile
CopperTree
53 posts in 1204 days
#4 posted 11-06-2016 06:43 AM
Standard pipe or bar clamps for me, a lot of them spaced evenly and clamped from both sides. They create the force necessary to close up any minor gaps and keep the blank flat while drying. I too have used PVC as an alignment aid but now just use the bars/pipes themselves. It’s easier to plan for an 1/8” misalignment and plane/sand it away than it is to align 20+ strips all at the same time. You can never have too many pipe clamps…
View Tom's profile
Tom
#5 posted 11-06-2016 08:59 PM
I don’t have any pipe clamps, just a bunch of the HF bar clamps that work great. Since my planer is 12” I make all my boards 11” wide and at $4 each the 12” clamps from HF are perfect. I did make a sloppy jig from some scrap pipe and 2×3 lumber, works great to glue the board up, get it mostly flat then move to a drying area.
I’ve also discovered that Bubinga (it’s red) looks REALLY cool in a cutting board and isn’t much more expensive than Walnut. Adding a few thin bits accents a board nicely.
