How far off center is the hole in the...
Forum topic by Loren posted 10-28-2016 05:19 PM 336 views 0 times favorited 2 replies Add to Favorites Watch
View Loren's profile
10380 posts in 3643 days
10-28-2016 05:19 PM
... round metal part of a Biesemeier fence cam clamp?
I have a vintage table saw with a sliding table so
I can’t use a standard fence. My options are to
either spend and arm and a leg or make my
own fence and I’m leaning towards the latter.
I can fuss around with wood to figure out the
offset of the pivot hole but I thought I would
ask first.
2 replies so far
MrUnix
6704 posts in 2194 days
#1 posted 10-28-2016 06:08 PM
I think you will need to fuss around with wood to figure it out anyway… since you are making the fence yourself and it most likely won’t be exactly the same as a Biesemeyer:
Distance from the edge of the hole to the widest outside part of the cam is ~0.60”, and at the narrowest is ~0.30”. That is from the commercial version (I have a BC50), so it probably will be different than what is on the homeshop version or the newer T2/T3’s.
#2 posted 10-28-2016 06:18 PM
Perfect. Thank you.
