Grizzly G1022Z TS bearings?
Forum topic by LucasWoods posted 10-28-2016 01:20 AM 526 views 0 times favorited 8 replies Add to Favorites Watch
View LucasWoods's profile
LucasWoods
445 posts in 1567 days
10-28-2016 01:20 AM
Grizzly does not produce replacement parts for this model anymore. What size or where can I can bearings for this TS
-- Colorado Springs, CO - USAF
8 replies so far
MrUnix
7100 posts in 2432 days
#1 posted 10-28-2016 02:23 AM
Pull them and look, and measure to make sure. Parts diagram shows 6203-2RS bearings for the arbor, but that does not necessarily mean that is what is in there. Do the same with the motor bearings (pull to verify what is in there), then give Lynne a call at Accurate Bearings and she will hook you up.
Bearings are off the shelf items, so never buy them from the OEM or aftermarket suppliers unless you want to pay out the nose for bearings of unknown origin. I’ve seen bearings sold by manufacturers specific for a particular machine that cost upwards of $30-$40, while the same bearing of better quality can be had at places like Accurate for around $4 a piece.
LucasWoods
#2 posted 10-28-2016 02:32 AM
Thank you very much brad
View Quanter50's profile
Quanter50
278 posts in 2530 days
#3 posted 10-28-2016 11:28 AM
If you have a Tractor Supply Store near you, they will have it.
LucasWoods
#4 posted 11-04-2016 03:29 AM
What information do i need to go in and buy the bearings? If I were to buy them from accurate bearings do they know what sizes are used or do I need to take down measurements etc?
MrUnix
#5 posted 11-04-2016 03:47 AM
Lynne doesn’t know squat about woodworking machinery – she sells bearings, so you need to tell her what you have/need. If you are positive of a specific bearing (eg: 6203-2RS), you can just ask for them by number and that is what she will send you. If you are not positive of the number, then measurements will help verify – and sometimes she will ask if you measured them just to make sure. With the measurements, she can help find the right bearing for you in that case. For example, the OD, bore and outer race width are identical between the 6203, 88503 and 87503 bearings, but the later have extended inner races that are wider than that of a 6203.
For general info, there is a ‘sticky’ in the OWWM forums titled something like “Ordering bearings from Accurate” that will give you all you need. Unfortunately, they have been having some server problems for the last few days and are currently down. You can check out the document when they are back up – unfortunately, I don’t have a local copy.
LucasWoods
#6 posted 11-04-2016 04:36 AM
Thanks brad even though everything you just said made no sense lol. Looks like I need to read that guide and get more knowledgeable about bearings
MrUnix
#7 posted 11-04-2016 06:51 PM
Don’t fret.. it’s not that hard :) There are really only a handful of bearing sizes you will run across on these machines, and the 62xx series is about the most common… yank yours and see what is stamped on the side, measure just to make sure, and you will be good to go.
And it seems like OWWM is back up, so here is the document I mentioned:
Ordering Bearings From Accurate Bearing - Please Read
LucasWoods
#8 posted 11-04-2016 07:15 PM
Thanks brad and will do.
