What joinery would you use for this table?
« back to Joinery forum
Forum topic by CharlesA posted 10-27-2016 07:16 PM 814 views 0 times favorited 17 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3351 posts in 1994 days
10-27-2016 07:16 PM
I’m looking at a table and trying to figure out how one would joint the legs to the base.
My thought. A carriage bolt entering the leg joint from the top in a recessed hole that would extend into a recessed hole in the base tightened with a nut. The recessed hole legs would be closed with a plug. Perhaps it would be stabilized with four dowels from the base into the bottom of each of the four legs, 2” off of center or so.
How would you do it?
17 replies so far
View Ron Aylor's profile
Ron Aylor
2649 posts in 844 days
#1 posted 10-27-2016 07:22 PM
Mortise and tendon all around … unless it needs to come apart!
View Loren's profile
10477 posts in 3844 days
#2 posted 10-27-2016 07:30 PM
My thought is the bottom part of the top may
have bolts through it going into threaded
inserts in the “legs”. Then the lacquered wood
top is dropped on over that. Hanger bolts
in the legs could work too. That rounded
white portion looks hollow to me, with a
plywood bottom.
Perhaps the painted part is just a curved apron.
In any case, the joinery of the legs shouldn’t
be too challenging with so much room to
work.
CharlesA
#3 posted 10-27-2016 07:42 PM
- Ron Aylor
Tell me more. I would have thought that a mortise and tenon joint from the base to those legs would be prone to snapping given that the locations would be so close to the center with the table extending so far out.
View jbay's profile
jbay
2858 posts in 1096 days
#4 posted 10-27-2016 07:46 PM
Yeah,
I should have given it more thought before I answered.
CharlesA
#5 posted 10-27-2016 07:49 PM
- Loren
threaded inserts is a good variation on what I was thinking. I think I’d be a little wary of a hanger bolt—I’ve never had much luck with them.
View robscastle's profile
robscastle
5432 posts in 2401 days
#6 posted 10-27-2016 08:12 PM
Agree with the above comments,
however as an alternative suggestion
1. Make the frame and attaach the legs from the top with screws.
2. Then attach the top from the bottom again with screws.
3. Repeat the process for the base
That way if it needs dis assembly late you can do it.
-- Regards Rob
View bigblockyeti's profile
bigblockyeti
5285 posts in 1917 days
#7 posted 10-27-2016 08:38 PM
Do you have any other pictures showing the relationship of the legs running to and from the photographer and the legs running to the sides? It kind of looks like the base of the pair running to and from are slightly higher than the base of the pair running side to side. If that’s the case, I’d make each pair as one and cut a half lap joint at the bottom then run a carriage bolt through as you have described.
#8 posted 10-27-2016 10:45 PM
I mention hanger bolts because there are hanger
bolt insertion machines used in making tables
in commercial settings. I think the machines
drill and then insert but I don’t recall exactly,
maybe they just put the hanger bolts in.
CharlesA
#9 posted 10-27-2016 10:47 PM
That’s interesting, Loren. I may just be reflecting finding them in particle board furniture.
Ron Aylor
#10 posted 10-27-2016 11:18 PM
Mortise and tenons all around … unless it needs to come apart!
- Ron Aylor
- CharlesA
Charles – This is what I was thinking:
View JBrow's profile
JBrow
1366 posts in 1117 days
#11 posted 10-28-2016 01:11 AM
CharlesA,
I cannot really add any meaningful comments regarding attaching the legs to the base beyond what has already been suggested. But I do favor using threaded inserts and bolts to attach the legs and the stabilizing outriggers to the base. I prefer threaded inserts since they seem to hold up better after repeated assembly and disassembly. The stabilizing outriggers that support the legs at the base could be glued to the legs. Loose tenons or dowels could be used to reinforce the stabilizing outriggers to the legs joint.
However, if a slight variation to the design is possible, the stabilizing outriggers could be eliminated, attaching the legs a made little easier, and additional space could be afforded for chairs to tuck under the table. If the legs are semi-elliptical rather than semi-circular, a flat spot could be cut into the elliptical legs where they meet the base without having to shave much off the legs where they meet the base. These elliptical legs could support a little larger top and thus provide a little more room for the chairs. The flat spot on the legs could be glued to the base where the legs run parallel to the grain of the base, either with a butt joint, or reinforced with dowels or loose tenons. Elongated holes in the base and screws could secure the flat spot of the legs to the base where the legs are perpendicular to the grain of the base. If disassembly of the legs from the base is required, threaded inserts installed in the flat spots on the elliptical legs and bolts through the base could be used.
View Woodknack's profile
Woodknack
12426 posts in 2577 days
#12 posted 10-28-2016 02:04 AM
I didn’t read the other replies so I’m probably just repeating everyone but the legs appear to be metal or cast acrylic, so I’d tap the legs and run a bolt through the bottom; or maybe a lag screw.
CharlesA
#13 posted 10-28-2016 01:50 PM
I didn t read the other replies so I m probably just repeating everyone but the legs appear to be metal or cast acrylic, so I d tap the legs and run a bolt through the bottom; or maybe a lag screw.
- Rick M.
I’d be shocked if those legs aren’t wood (even if hollow).
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2566 days
#14 posted 10-28-2016 02:13 PM
I like Loren’s suggestion of hanger bolts. I’ve used them to connect solid oak railings to newel posts. Forget the particleboard stuff, in solid wood, those things are extremely solid.
Woodknack
#15 posted 10-28-2016 03:30 PM
I d be shocked if those legs aren t wood (even if hollow).
- CharlesA
Do you have information about it besides the picture? Because it doesn’t look like wood. Where did you get the pic? If they are wood they are probably laminations.
