How long to let face glued ply dry?
« back to Joinery forum
Forum topic by cag0331 posted 10-26-2016 09:41 PM 450 views 0 times favorited 4 replies Add to Favorites Watch
View cag0331's profile
13 posts in 514 days
10-26-2016 09:41 PM
Topic tags/keywords: plywood face glue glue up glue time
Hello, I was just wondering if someone could tell me how long I should let 2 pieces of 3/4” Baltic birch ply that are face glued dry before I can run them through the TS and final dimension them? My concerns with not waiting at least overnight are: could cutting have too soon cause them to warp? Can glue that is still possibly tacky ruin my blade? Anyone have input? Thanks!
View bilyo's profile
147 posts in 1037 days
#1 posted 10-27-2016 01:29 AM
I think that the directions on the glue bottle will recommend how long to wait before “working” the joint. Usually about 8 hours, I think.
I don’t think that the glue will ruin your blade but you may have to clean it to keep from leaving burn marks on future cuts.
View Carloz's profile
1147 posts in 526 days
#2 posted 10-27-2016 04:11 PM
If you are using Titebond it depends how you use it later. If it is a stressed joint you should wait 24 hours. Non-stressed 30 min to 1 hour.
View JBrow's profile
1341 posts in 855 days
#3 posted 10-27-2016 04:33 PM
I am risk averse by nature. Therefore, I would wait until the glue is fully cured, based on curing time stated on the glue bottle. This way if something bad happens after making the cuts you do not have to wonder whether the problem could have been avoided had you let the glue cure a little longer.
View MrUnix's profile
6494 posts in 2134 days
#4 posted 10-27-2016 04:44 PM
If it’s PVA glue, then it dries pretty quick… Titebond recommends 30 minutes to an hour for an unstressed glue joint, which is pretty typical for other PVA glues as well. An hour or two should be more than enough. For other glue types, consult the manufacturers recommendations.
