What to do about the end grain on cut reclaimed boards
Forum topic by Brodimus_Max posted 10-26-2016 05:37 PM 621 views 0 times favorited 6 replies Add to Favorites Watch
View Brodimus_Max's profile
Brodimus_Max
10 posts in 1826 days
10-26-2016 05:37 PM
Topic tags/keywords: reclaimed barn barn wood aging finishing end grain
I bought several oak 2×6’s from a guy who takes down barns and sells the lumber. The boards are beautiful, and some have a bit of a live edge. I’m building a counter height dining table with them that will be 7’ long. I’m going for a very simple look and will jointer the interior edges. The boards are varying lengths and need to be cut to length. This will leave me with a freshly cut end grain. I don’t know how to finish this so that the look will be the same. Anyone have experience with this? I’ve read of a few techniques for “aging” wood. Any help here is greatly appreciated.
View bondogaposis's profile
bondogaposis
4931 posts in 2472 days
#1 posted 10-26-2016 05:51 PM
Experiment with stains and dyes until you get a match.
-- Bondo Gaposis
View saddletramp's profile
saddletramp
1180 posts in 2759 days
#2 posted 10-26-2016 06:03 PM
If you have enough wood, make bread board end caps.
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
View bigblockyeti's profile
bigblockyeti
5207 posts in 1841 days
#3 posted 10-26-2016 06:12 PM
^ +1 to the bread board idea, that would be my first approach. You might also be able to apply some iron acetate to darken the wood, if it’s red oak it should darken up pretty good, from there you can distress it to your liking.
View mike02130's profile
mike02130
170 posts in 793 days
#4 posted 10-26-2016 06:15 PM
Use a ragged hand Saw and rub some dirt in. It works.
-- Google first, search forums second, ask questions later.
Brodimus_Max
#5 posted 10-26-2016 06:18 PM
Thanks for the feedback. I considered the breadboard idea, but unless I make them out of new stock, they will also have cut ends. Also, I’d like the preserve the partial live edges on the outside edges of the table making the breadboard ends more complicated. I also like the simple look of parallel boards.
View Ripper70's profile
Ripper70
1114 posts in 1029 days
#6 posted 10-26-2016 06:29 PM
Not sure if this would work for you. I once worked in a shop that made tables from reclaimed lumber, mostly Douglas fir, and we would assemble the tables and then bleach them with Daly’s to get them uniform. Then use BriWax to finish. They turned out great. Breadboard ends were also used and had the benefit of adding stability to the tops to prevent twisting.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
