5/4 Oak for Shaker Cabinet doors - too thick?
Forum topic by HickWillis posted 10-26-2016 02:05 PM 1324 views 0 times favorited 7 replies Add to Favorites Watch
View HickWillis's profile
HickWillis
114 posts in 894 days
10-26-2016 02:05 PM
Hi all,
I just began the process of milling my lumber for some shaker style cabinet doors I am making for my kitchen. I got 5/4 red oak and am wondering if it is maybe too thick? I went to 5/4 so I could 1/2” ply for the inserts. Should I consider planing this down a little bit or would 5/4 look fine in a kitchen?
-- -Will
7 replies so far
View pintodeluxe's profile
pintodeluxe
5815 posts in 3048 days
#1 posted 10-26-2016 03:08 PM
Well 5/4 will net out at 1” thick. I think that’s a little too thick for my taste, especially if the cabinet doors are overlay style. However, I almost always start with 5/4 stock regardless of the final thickness. It is just easier to get flat, straight stock when you start with 5/4.
I would shoot for 7/8” thick. If you don’t like it, you can always plane it down to 3/4”.
View DS's profile
DS
3044 posts in 2655 days
#2 posted 10-26-2016 03:14 PM
Most ultra-high-end (read expensive) cabinetry uses thicker doors. Just keep in mind that this requires a thick door hinge.
Most one-piece production cabinet hinges can’t handle the throw out on a door that thick.
So, unless you can mount these with a Euro style thick door hinge, you’ll need them to be thinner.
My preference says thicker is better.
View waho6o9's profile
waho6o9
8539 posts in 2811 days
#3 posted 10-26-2016 03:27 PM
If the drawer fronts are the same you should be okay with that.
The industry standard is 3/4 though.
View 000's profile
000
2859 posts in 1134 days
#4 posted 10-26-2016 03:50 PM
Most door companies will offer a thicker door (7/8”)
I just made some shaker doors that were 1” thick with a 3/8” panel.
I prefer a thicker door, there just better all around.
waho6o9
#5 posted 10-26-2016 04:03 PM
Nice reveal on your well made doors jbay!
HickWillis
#6 posted 10-26-2016 05:17 PM
Most one-piece production cabinet hinges can t handle the throw out on a door that thick.
So, unless you can mount these with a Euro style thick door hinge, you ll need them to be thinner.
- DS
I can mount them Euro style – just need to locate the correct door hinge to allow for the thicker doors.
-- -Will
HickWillis
#7 posted 10-26-2016 05:17 PM
- waho6o9
Drawer fronts will be the same thickness – however I’m making the drawer fronts a solid piece (no insert). Saw a few pictures of kitchens with this style and I liked it.
-- -Will
