Using N52 Neodynium magnet or Magswitch to install drawer slides
Forum topic by nrs250 posted 10-25-2016 08:21 PM 454 views 0 times favorited 3 replies Add to Favorites Watch
View nrs250's profile
nrs250
1 post in 635 days
10-25-2016 08:21 PM
Has anyone tried to use a series of neodynium magnets (N52) by themselves or as part of a jig to hold a drawer slide in place during installation. I would think that these easily have the power to hold a 2 lb slide firmly in place through 3/4 inch hardwood. The magswitch variety is more expensive and I am not sure they would be strong enough.
3 replies so far
View splintergroup's profile
splintergroup
2151 posts in 1276 days
#1 posted 10-25-2016 08:25 PM
You probably would still get some movement issues.
Kreg makes a nice jig that you could copy some ideas from, I just use scrap masonite to act as a spacer from the cabinet bottom. The slide rests on the spacer and gets screwed down, the spacer insures each side is even and parallel.
View MrRon's profile
MrRon
4863 posts in 3297 days
#2 posted 10-26-2016 06:37 PM
Harbor Freight has a cheap magnetic base used to hold dial indicators for $12.95 less discount coupon that has a 45# pull. Might work for you. It would have other uses as well, like a stand for a work light or magnifying glass or dial indicator. I have several and find new uses for them.
View ChrisK's profile
ChrisK
1979 posts in 3135 days
#3 posted 10-26-2016 07:55 PM
The magnet is only half of the issue. There needs to be enough metal to allow the full force of the magnet to be generated. A magnet that can lift 45# may only generate 15# of pull with a thin part. See K&J Magnetics web site. Lots of info and calculators for magnet stuff.
A draw slide is pretty thing and you may need several magnets along the length to keep it in place.
-- Chris K
