Stablizing knots with Epoxy and top coat adhesion??
Forum topic by Ivan posted 07-09-2010 04:25 PM 1265 views 0 times favorited 5 replies Add to Favorites Watch
View Ivan 's profile
Ivan
185 posts in 3280 days
07-09-2010 04:25 PM
Topic tags/keywords: question oak finishing
Hello all,
I am getting ready to install some flooring, oak (red and white mix) that has some knots in it. I was originally thinking of cutting them all out, but some are nice and I’d like to include them.
I was thinking of filling any voids with epoxy and this cracks around knots with CA glue, then using a floor poly over top, but I’m not sure if the poly will adhere to the epoxy.
Other ideas on how to fill voids in/around knots??
-Ivan
-- "Do it right the first time, you'll just kick yourself later..."
5 replies so far
View Les Hastings's profile
Les Hastings
1305 posts in 3676 days
#1 posted 07-09-2010 04:46 PM
Not sure if finish will adhere to CA glue, but I know it will to West Systems marine epoxy. Most turners use CA glue as a filler though and finish over it though, so I don’t think that should be a problem.
-- Les, Wichita, Ks. (I'd rather be covered in saw dust!)
View Shopsmithtom's profile
Shopsmithtom
788 posts in 4098 days
#2 posted 07-09-2010 05:17 PM
I would do a test on some scrap being sure to scuff the areas of CA & epoxy first before applying the finish. After it dries, put it in the sun to get hot, let it go back to room temp & put it in the freezer to get cold & then let it get back to room temp, and then try scuffing or scraping a bit to see if it is holding.
I think the temp extremes will be a good test of durability.
-- Accuracy is not in your power tool, it's in you
View Gregn's profile
Gregn
1642 posts in 2886 days
#3 posted 07-09-2010 06:51 PM
I have used epoxy to place some Purpleheart eyes in a Oak rocking horse which left a ring of epoxy around the eyes. After sanding I applied polyurethane for a finish. So far there has been no problems with the finish. As for using CA glue I can’t say how it would work. You could fill the cracks with epoxy and sand flush and should have no problems.
View rusticandy's profile
rusticandy
110 posts in 3433 days
#4 posted 07-10-2010 05:56 AM
I spray Target coatings over both CA glue and epoxy every day- and have never had an issue
-- rustic andy
Ivan
#5 posted 07-12-2010 03:17 PM
Guys,
Thanks for the help, truly appreciated. I’ll take pics as I go and post progress reports. So far I have got a shop full (and I mean full) of flooring pieces.
Ivan
