Do I need to thin water based polyurethane when spraying ?
Forum topic by Carloz posted 10-24-2016 04:19 PM 1680 views 0 times favorited 4 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 674 days
10-24-2016 04:19 PM
Do two stage HVLP such as Fuji Semi Pro 2 or Earlex 6002 ( 5 and 4.5 psi) have enough pressure to spray General Finishes High Performance Water Based Top Coat ( What a name !!! ) without thinning ? The manufactures are vague on this.
5034 posts in 2576 days
#1 posted 10-24-2016 04:57 PM
I’ve sprayed it with my Fuji 4 stage and a 1.8mm needle set though I think I did thin it 10% with water. Be careful to not add more water than the manufacturer says, it can screw up the coalescing process.
Carloz
#2 posted 10-24-2016 05:16 PM
Just found it: The guy from General Finishes. sprays it with a much less powerful Earlex 5500 without thinning.
View AlaskaGuy's profile
AlaskaGuy
4269 posts in 2391 days
#3 posted 10-24-2016 05:42 PM
It would really be nice if finish manufacture woulds would put the viscosity time on the label.
Example: 25 seconds in a #4 ford cup. It would make it so much easier to pick a spray tip size and pressure.
http://homesteadfinishingproducts.com/wp-content/uploads/2014/05/paintspraying_ver3.pdf
View rwyoung's profile
rwyoung
409 posts in 3554 days
#4 posted 10-24-2016 07:22 PM
Viscosity is given on the technical data sheet (but not the label).
https://generalfinishes.com/sites/default/files/file_downloads/tech-data-ef-high-performance-poly-2014-07-28.pdf
Given as 35-45 seconds with a Ford #4 at 77F. Quick survey of Fuji manual suggests they want 15-18 seconds for polyurethenes and the 2mm N/N set. However this could be the wrong manual.
All such numbers extracted from manuals and data sheets are merely starting points for setting up the system(s). Test prior to spraying a project. Big sheet of cardboard makes a good target, reasonably simulates spraying a wooden surface.
-- Don't sweat the petty things and don't pet the sweaty things.
