Miter Saw Blade Deflection
Forum topic by jay443 posted 10-24-2016 12:27 AM 2221 views 0 times favorited 11 replies Add to Favorites Watch
View jay443's profile
jay443
16 posts in 802 days
10-24-2016 12:27 AM
I’m having a heck of a time with miter saw blade deflection when cutting miters on tall stock.
No matter what I do, I can’t seem to get a nice miter. You can see it in the picture below. A few more details:
-Only happens when trying to miter at an angle. A zero degree cut is just fine.
-Doesn’t matter how much I try to pull straight down on the miter saw head, it’s always here
-The deflection can happen at the top or bottom of the piece—can’t seem to figure out a pattern
My miter saw is a Dewalt DW717, 10’’ sliding miter saw. I read the “tune-up” series at thisiscarpentry.com and I aligned the saw.
Any suggestions? Thanks.
11 replies so far
18207 posts in 1857 days
#1 posted 10-24-2016 12:40 AM
Does it happen when cutting a board in half or when just trimming a bit off. I use a very thick blade with 96 teeth to prevent this from happening. I’m thinking it’s a thin blade and it deflects when it hits differences in the grain of the wood. Kind of like a screw that wants to go in and follow the grain.
jay443
#2 posted 10-24-2016 02:00 AM
It happens during both, unfortunately. It drove me crazy because I tried going really, really slowly through the board and pulling straight down, and it came out worse than when I went quickly. I am using a thin kerf blade, though, a Freud Diablo 60 tooth. I wonder if it would be worth finding a full kerf blade.
View splatman's profile
splatman
586 posts in 1399 days
#3 posted 10-24-2016 02:07 AM
That might explain some of the issues I’ve had when cutting on my 10” CMS. Do try a full-kerf blade and tell us and show us the results.
View wichman3's profile
wichman3
63 posts in 621 days
#4 posted 10-24-2016 03:18 AM
Are you clamping the piece(s) when you cut? do you have a non-slip surface on the mitre saw fence (180 or better sandpaper)
If the results are worse when you cut slow, then I would suspect that the piece is slipping while you cut.
Also, are you using a tall auxiliary fence?
- jay443
View MadMark's profile
MadMark
979 posts in 1453 days
#5 posted 10-24-2016 04:27 AM
Are you pressing the stock (too) hard against the blade? Test: set the miter and clamp the piece in place and cut ‘no hands’. if problem stays, tool is broke/bent. If the cut is correct then always clamp.
M
View jumbojack's profile
jumbojack
1676 posts in 2624 days
#6 posted 10-24-2016 05:06 AM
I think Madmark has it. Start the cut s l o w l y. Be sure the material is firmly clamped or otherwise fixed so No movement occurs. I don’t think you mentioned the blade you are using but a quality full left blade will certainly help.
View mike02130's profile
mike02130
167 posts in 673 days
#7 posted 10-24-2016 11:59 AM
Check the fence to see if it’s vertically squared to the table. The DeWalt come with a high sliding fence. They’re never square. I added some strips of painter’s tape. Helps some.
Why cut vertically rather than flat?
-- Google first, search forums second, ask questions later.
#8 posted 10-24-2016 12:11 PM
Wichman has a point. If it’s happening only on miters, the angle of the blade wants to slide the board in the direction the blade is facing.
wichman3
#9 posted 10-24-2016 12:23 PM
Here’s an idea to try: Keep the blade at 0, tilt the blade to 45, lay the piece flat and then cut. Check the results.
jay443
#10 posted 10-24-2016 12:30 PM
Thanks everybody for the replies! I will try out all of your suggestions. But I can say that currently I wasn’t clamping the piece because I felt like I had a good grip on it. I will try these things tonight:
- check the fence for perpendicular
- clamp the piece and cut at a 45 deg miter
- lay the piece flat and cut a 45 deg bevel to create the same miter
mike02130
#11 posted 10-24-2016 01:14 PM
Try my suggestion first. It may save you some frustration. I don’t know much but I’m usually right. I just cut a miter with a 1×6 standing vertically against the fence and this is what happened.
When I put a square against the fence, it shows that it is tilted back almost a 1/16. Hard to tell by the picture but it shows you how and where to set your square.
No need for a clamp, no need to cut slowly, just hold and cut like you would normally do.
