Music Stand Dimensions
Forum topic by DonJ posted 07-08-2010 11:28 PM 6209 views 0 times favorited 4 replies Add to Favorites Watch
View DonJ's profile
250 posts in 3460 days
07-08-2010 11:28 PM
I want to build a music stand but don’t know what might be considered standard dimensions of height (I would guess the travel should be between a sitting and standing position). Also, what might be a typical size for the platform that holds the book or music? I have no turning capabilities, so will make a square style pedistal. I’ve kept various photos of completed music stands on this forum, so have a design in mind, but thought I might work on my SketchUp skills while I’m at it…hence the desire for some dimension info. Thanks so much, as always.
-- Don, San Antonio, TX
16273 posts in 4151 days
#1 posted 07-09-2010 12:52 AM
Sheet music is generally on 8 1/2×11 paper, so a stand should be big enough to hold an open booklet, roughly 18” wide x 12” high, or slightly smaller. There should be a ledge at the bottom about 1” or so wide to hold the music. Travel would be just as you said.
View robdelman's profile
8 posts in 2811 days
#2 posted 07-09-2010 05:32 AM
Take a look at this stand on Musicians Friend. You can work the dimensions from the given height.
There are a lot of other stands there as well, I recommend looking at the metal stands first and assessing the dimensions.
-- Rob, Ohio,
View Dark_Lightning's profile
3115 posts in 3041 days
#3 posted 07-09-2010 05:37 AM
We have a music stand laying on the front porch that my wife dragged home from who knows where. But the thing is adjustable, so I won’t be much help unless you want to know minimum height versus maximum height.
-- Random Orbital Nailer
View DonJ's profile
#4 posted 07-09-2010 03:58 PM
Thanks all; I think I have enough to get the rough dimensions and height travel. I’m going over to SketchUp now and plow through that for awhile. I’m going to try to do something similar to what Eiji has posted; I won’t get close to his finished product, but will make one that should have some utility in it.
