Veneer staining after gluing
Forum topic by rwe2156 posted 10-22-2016 01:18 PM 1333 views 0 times favorited 37 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
3087 posts in 1622 days
10-22-2016 01:18 PM
Only one of the drawer fronts came out like this.
The streaks are actually grey in color.
I’m thinking the glue bled through but what do you all think?
I used Titebond Cold Press Glue.
37 replies so far
View JBrow's profile
JBrow
1366 posts in 1061 days
#1 posted 10-22-2016 02:05 PM
rwe2156,
Since I have no veneering experience and have not used Titebond Cold Press glue, I cannot say whether it is glue, something else, or glue bleed through in combination with something else. For what it is worth, it seems to me…
It appears the veneer has some cracks, similar to checks, radiating out from the center of the swirl grain pattern and parallel to the grain. If so, then an easy path for migration of the glue is available. That leaves me wonder whether a small amount of glue may have made contact with some fine grim and dirt that may have been on the clamping caul. When the caul was removed, the dirt remained behind. The gray color is reminiscent of the grim I sometimes observe on MDF in the home center. If so, then perhaps the gray color is on the surface and does not penetrate the veneer.
If a little sanding makes no difference, then I would think it is veneer saturated with cured glue. The swirl grain suggests to me that a knot or other feature was present in the log as the veneer was peeled away. If so, the vessels that conduct water up and down the tree could be angled toward (rather than parallel to) the surface of the veneer, offering a path for some glue migration. If it is bleed through, then the gray color is either the color of the cured glue or the product of a reaction of the glue with chemicals in the wood.
View jbay's profile (online now)
jbay
2661 posts in 1041 days
#2 posted 10-22-2016 02:20 PM
What kind of veneer? paper backed, wood on wood, natural?
It sort of looks to me like the veneer was thinner in that spot and the backing is showing through.
or, it looks like it could have been sanded to much from the top.
Did it not show any of that before you started?
View shipwright's profile
shipwright
8085 posts in 2939 days
#3 posted 10-22-2016 03:06 PM
I only glue veneer with hide glue but it looks like you may have over sanded.
Was it like this right off the bat or only after sanding?
Raw veneer or backed?
Vacuum bagged or clamps?
More info will help us help you. :-)
rwe2156
#4 posted 10-23-2016 01:23 AM
Plain veneer. It was there right from the start.
Pic was taken after some scraping which made it worse.
I used clamps.
It is a figured cherry veneer. It was the only one that did this.
I’m thinking what Jbrow said might be what happened because I think I used too much glue.
shipwright
#5 posted 10-23-2016 05:01 AM
Have you ever considered hide glue?
http://lumberjocks.com/shipwright/blog/series/5437
View tomd's profile
tomd
2166 posts in 3912 days
#6 posted 10-23-2016 05:59 AM
I use Titebond veneer glue and it looks like some may have bled through. I find you have to be very stingy with that glue.
-- Tom D
rwe2156
#7 posted 10-23-2016 11:46 AM
Yes I was actually looking at hide glue but all I have is titbond and I wasn’t sure about it.. I’ve heard it helps to warm it up.
If that will work I will use it.
BTW the other day I happened to watch an episode of Tommy Mac he used standard yellow glue
View Lazyman's profile
Lazyman
2484 posts in 1529 days
#8 posted 10-23-2016 02:47 PM
Thanks for sharing this. I’ve been experimenting with hide glue in preparation for applying some walnut veneer and it is pretty amazing stuff. This helps to convince me even more to not use PVA for the thin veneer I have. Another option (that shipwright recommended to me when I posted a question about glue and veneer) rather than the hide glue that takes more time to prep is Old Brown Glue which is a (more) shelf stable premixed liquid hide glue. Might be worth a look for your application.
View Loren's profile
10477 posts in 3789 days
#9 posted 10-23-2016 06:39 PM
Unless you want to do it over or live with it as
is I suggest dry brushing with the flat acrylic
model paints sold for lead figurines. I’ve done
that and it can improve a situation.
rwe2156
#10 posted 10-23-2016 09:24 PM
Thanks guys. I have a few scraps to practice with I think I will warm up that titebond hide glue and see how it works. But I gotta get this veneer off because I threw on some blo thinking the stain might not be so noticeable :-(
View jumbojack's profile
jumbojack
1685 posts in 2765 days
#11 posted 10-24-2016 04:55 AM
I threw my Titebond Cold Press glue away for the very reason you have outlined. Bleed through. I do quite a bit of veneering. The liquid hide is better than the cold press but the hot hide is superior. The start up is a little steep but WELL worth it.
shipwright
#12 posted 10-24-2016 06:19 AM
I veneer lots too and agree with jumbojack. Hot hide glue is my go to glue and there are lots of heat sources that won’t cost you a lot. Check the blog. There is a discussion on them in the second segment.
Also if you had used hide glue, it would be easy to remove the old piece.
I don’t think heating Titebond LHG is necessary. It is a liquid at room temp I believe and heating it will likely just make it really runny and hard to control. If you were using Old Brown Glue, my preferred LHG, you would heat it a little as it is a gel at room temperature but even with it warmer than required to liquefy it can make it way too runny.
rwe2156
#13 posted 10-24-2016 12:18 PM
Appreciate the tips, Paul.
rwe2156
#14 posted 10-24-2016 01:24 PM
Hey another question: the veneer is figured cherry looked pretty nice.
I noticed after a little scraping and sanding the figure doesn’t seem as prominent. I primer coat of BLO brought it back a little, but overall it it seems a “duller” than it was right out of the box.
Is there a certain way to smooth figured veneers for finishing?
Also, is there any advantage to backing vs. raw veneer? (I’m using unbacked veneer).
View DrDirt's profile
DrDirt
4462 posts in 3884 days
#15 posted 10-24-2016 01:34 PM
I prefer unbacked veneer
Did you happen to try wiping a bit of Oxalic Acid? If the blue/gray is some iron staining, it will go away.
I never had it with a ‘blotch’ like that but I made Cherry Shaker Boxes, and had a problem with ‘freckles’ after soaking and bending it. Tied to Iron in the water.
I get it at Ace Hardware, dissolve a teaspoon full into a 1/2 cuo of water andwet it… it will either fix it (watch it fade away in a few minutes) or it will do nothing and you only lose 10 minutes + the time for the wood to dry back out.
showing 1 through 15 of 37 replies
