10 inch bench-top drill press table
Forum topic by Jose posted 10-21-2016 01:57 PM 666 views 0 times favorited 2 replies Add to Favorites Watch
View Jose's profile
Jose
102 posts in 1802 days
10-21-2016 01:57 PM
I want to build a table for my drill press and want to know how this can be done without the height adjustment arm interfering with it. What I have now is a piece of plywood but I had to cut a piece off on an angle for the adjustment arm to freely move. I want to build something similar to what is shown on the second picture below. Suggestions are welcome.
-- Jose
2 replies so far
View MrRon's profile
MrRon
5089 posts in 3392 days
#1 posted 10-21-2016 08:43 PM
If possible, remove the crank and replace it with a large hand knob. A table top drill press doesn’t need much table travel. Looking at the second picture, it looks like you will be losing about 4” in chuck-to-table distance. If you can, place the plywood top on the table and have the storage below the table. You can use a scissor jack or a bottle jack under the table to raise/lower it instead of using the crank.
View Adam's profile
Adam
41 posts in 2377 days
#2 posted 10-21-2016 08:55 PM
The May 2014 (Issue 135) issue of Shopnotes had a pretty ingenious solution: Move it. I can’t get a picture of mine right now, but Here’s a link to another LJ who built it:
http://lumberjocks.com/projects/128865
It actually wasn’t that difficult to put together.
