| Forum topic by Steelwinky | posted 550 days ago | 3295 views | 0 times favorited | 18 replies | ![]() |
550 days ago |
549 days ago |
Check this out for a design What kind of material did you buy? |
549 days ago |
Actually, it was a piece of bowling lane. Apparently some sort of synthetic with a very dense core. |
549 days ago |
Obi, maybe you should send him a copy of that vertical/horizontal router table. I think that would be great to build. A hole saw should work for what you need, if it is just a hole. If you are going to put a plate in instead, then you just have to cut out a square or rectangle instead. -- Bill, Turlock California, http://www.brookswoodworks.com |
549 days ago |
Yeah, maybe a hole would be ok. I was thinking a plate, but i can really see no reason that a hole wouldn’t work. Also, I think a horizontal/vertical table would be great. I have ran into a sitiation where I was trying to rout the end of a board 6 feet long, and had it standing straight up in the air. |
549 days ago |
I bought the Woodhaven Horizontal router table I use it for mortises. When I was building my cradle I needed mortises at 8 degrees. And this tool allowed me to do that. After some modifications on my part. I suggested to the mfg make those modifications on the ones they sell and I believe that they did. -- Karson Southern Delaware karson_morrison@bigfoot.com |
549 days ago |
It sounds like they need to make a table that will go from vertical to horizontal, and all points in between. That would allow you to do the mortises at any angle you needed. I am not an engineer, but it seems like that would be doable at least. -- Bill, Turlock California, http://www.brookswoodworks.com |
549 days ago |
There was a table like that, that was shown at woodworkers shows. I believe that they were bought by Hawk In fact here it is. -- Karson Southern Delaware karson_morrison@bigfoot.com |
549 days ago |
After looking at both of those tables, I think I want to make that mortise jig vertical. That way I can move the stick instead of moving the jig. |
549 days ago |
Obi: I’m confused by your comment. Were you referring to both of the tables that I linked too. If you were, in your comments about moving the stick instead of the jig. Were you referring to the Woodhaven or the Hawk tables? -- Karson Southern Delaware karson_morrison@bigfoot.com |
549 days ago |
Steelwinky, |
549 days ago |
Karson the woodhaven table gave me the idea that i could fix my jig, and steelwinky your link is dead |
549 days ago |
Obi: Its a nice table. They also have a router mount that you can set your router at any angle from 0 to 45. I bought it and have installed it but that feature is unused. I mounted a Harbor freight digital caliper on the table so that I can adjust the router bit with more accuracy -- Karson Southern Delaware karson_morrison@bigfoot.com |
549 days ago |
I just built one it was only my second project and it works great. The plan is in Bill Hylton router book. -- Billp |
548 days ago |
Here’s a How to, to build a Router table, that’s a fairly simple design -- Dick Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
548 days ago |
I have a 20 year old Delta contractor’s saw that I inherited from my grandfather. Since I already had a table saw I decided to remove one of the steel wings from the Delta and replace it with a router table. It’s a simple table made of birch plywood with a store bought mounting plate. I made a dust collection fence for it that attaches to the table saw fence. It works great for everything I do, and it saves shop space. -- JP, Shelbyville, KY |
548 days ago |
A great space saver JP. Sounds like your has worked out just great. Thanks for the link Dick. One more for my workplans book. -- Bill, Turlock California, http://www.brookswoodworks.com |
548 days ago |
I’m glad the link worked, some of the Fine woodworking links,can only be seen by subscribers. FW internet has a lot of stuff , if you’re a member. It covers just about anything. I recommend this to everyone. -- Dick Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
547 days ago |
Steelwinky, What you have is a piece of laminate. It is made from resin impregnated paper and pressed under high pressure and heat. Generally around 1100-1200 psi and 300 degrees. When you cut or drill into it, I would recommend using carbide tooling if possible. The top layer most likely has aluminum oxide in it for wear resistance. This can wreak havoc on tools. The good thing is you won’t need to worry about wearing out the surface. This material also makes excellent benchtop material as I have several pieces at home :-) -- Brandon, Maine, www.maineweddingtrellis.com |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1141 |
1528 |
103 |
299 |
95 |
Woodworking Trade & Swap
211 |
Coffee Lounge
838 |
LumberJocks.com Site Feedback
256 |
The router table slides up and down on a aluminum track. It wouldn’t be hard to construct something like this.
